R56 HELP! Whats this?
It's definitely not coolant or road salt. It feels rough on the white area and it can't be removed. Could it be excessive heat in the region or heat from the turbo?
My aftermarket turbo is not shielded. During a track session, turbo heat melted the valve cover in that same area, but there was no white residue, just oil leakage from a warped valve cover.
You might try removing the "snap-on" harness cover from the valve cover to see if the white residue source is there. Hopefully not, but it's easy enough to do. Valve cover gasket definitely looks bad, causing the oil residue. Also pretty easy to change without special tools.
That white stuff is the melted aluminum blowing onto the valve cover. Take a better photo for us.
I dont know if its the heat going around the heat shield ( little add on part ) or the bottom one or the wires under the plastic are arcing or getting hot ( ignition ) . Clip out and pull up that black piece ( when the engine is cooler ). Goes all the way across and hold the ignition wire before the coils. See whats going on with the misfire.
https://www.northamericanmotoring.co...ment-help.html
Wish I would have kept two of my old valve covers. My downpipe came loose and it blew hot exhaust straight across that corner of the valve cover. It also started to melt a hole in the heat shields. When I get up tomorrow I will post pictures. I still have the last valve cover and the heat shields. That hole is the only place for exhaust to escape when there's a leak.
