R56 Is there a way to find the BMW/Mini part number of a known X connector number?
Old 01-13-2015, 02:47 PM
bratling's Avatar
bratling
bratling is offline
Super Moderator
I've been trying to figure out how to find a BMW/Mini part number based on something I know exists from the wiring schematics.
Specifically, I'm looking for an X10387 connector (which plugs into the nav system's joystick, aka component A167b). I'm also looking for X13820 and X13823.
So far, I've had no luck using realoem.com (which doesn't have much in the way of electrical connectors in the diagrams) or bmw-planet.com's WDS (which has electrical info galore but not the part numbers I need to order bits).
Someone must have run into this challenge before. Anyone?
Thanks!
Old 01-13-2015, 07:41 PM
sgscomps's Avatar
sgscomps
sgscomps is offline
Call your dealer, their software has the connector and terminal part numbers
Old 01-14-2015, 05:45 AM
v10climber's Avatar
v10climber
v10climber is offline
I've never had luck digging up electrical connector part numbers for any of my cars. If you find a source for the BMW ones that would be awesome!
Old 01-14-2015, 11:29 AM
SPRINTCARS's Avatar
SPRINTCARS
SPRINTCARS is offline
Yup, gotta call the dealers. I had to replace the connector after the aux water pump decided to enter the nuclear melt down stage and become a plastic blob. There a pain in the *** to assemble just as a heads up. Take your time and get a wire diagram as well.
Old 01-19-2015, 03:42 PM
bratling's Avatar
bratling
bratling is offline
Super Moderator
I took you guys' advice and called the parts department at MINI of Peabody. Tom took some notes and said he would have to do some digging and will get back to me with parts. He warned that some cables aren't available already assembled and that I might have to make them myself from the parts. No problem, I can do that.
Crossing fingers.
Old 01-20-2015, 10:18 AM
bratling's Avatar
bratling
bratling is offline
Super Moderator
My dealer couldn't figure out the part numbers from the WDS info or their parts lookup system.
Frustrating.
Old 01-20-2015, 10:40 AM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
Sometimes on the part the last 7 digit of the part number are there, on the part molded in. . Find them and I can help.
Old 01-21-2015, 03:39 PM
bratling's Avatar
bratling
bratling is offline
Super Moderator
Not sure if this will do the trick — I haven't found the connector itself, but I *can* tell you it plugs into part 65823449102. (Part number verified against the joystick module sitting on my desk.)
Here's the WDS diagram I'm working off of:
And here's the part itself — the X10387 plugs into the keyed 4-pin socket you can see at lower right:
Attached Thumbnails Is there a way to find the BMW/Mini part number of a known X connector number?-diagram.jpg   Is there a way to find the BMW/Mini part number of a known X connector number?-x10387-goes-here.jpg
Old 01-27-2015, 06:33 AM
Thanks, it look like 61138380696
http://www.ecstuning.com/Search/SiteSearch/61138380696/ES2675906/
But the steps on the right hand side look like more steps then that, but looks to still fit.. You can give is a shot. That the only one I could find right now.
65823449102 SS to 65823456246
Navigation Unit Controller
http://www.ecstuning.com/Search/SiteSearch/65823456246/
Old 01-27-2015, 07:07 AM
percymon's Avatar
percymon
percymon is offline
For reference there is a separate section on RELAOEM with some of the elctrical connectors on, albeit its not easy to match them up to where in the car they are or which looms they belong to.
Old 01-27-2015, 03:17 PM
bratling's Avatar
bratling
bratling is offline
Super Moderator
You are a star. That looks like it should fit the keying. I've just put that and the pin terminals into my cart, added some wipers I need too. Used your link so you should get credit for the sale.
Old 01-28-2015, 05:29 AM
Thank you. Glad I could help. Good luck with the fix.
Wohnson89
06-10-2020 04:53 AM
ryGuyMCS
10-20-2015 02:24 PM
David.R53
09-01-2015 06:51 PM
xraycat
08-15-2015 06:43 AM
nomar116
08-10-2015 11:24 PM
Quick Reply: R56 Is there a way to find the BMW/Mini part number of a known X connector number?
