R56 2009 cooper engine light
my check engine light is on the dealer scanned it and it indicates a bad water pump and thermostat the car runs fine and does not over heat what could be wrong? i need to correct this problem soon because the inspection sticker expires at months end the car has 94,000 miles
What did you find the problem(s) to be? Sorry no one responded to you. Some additional information might have gotten better results. You got a CEL, but without the codes, the dealer's diagnosis is what you get pretty much. Water pumps and thermostats are pretty common failures, particularly over 60,000 miles. I hope that you have been watching your coolant reservoir that it has been consistently full without adding any antifreeze. The thermostat has an electrical sensor in it that keeps an eye on it, besides leakage. Water pumps just leak. The CEL could be triggered for any number of reasons that point to there being a coolant system problem. Find an esteemed independent who knows MINIs to do the work if you cannot. Searching for common issues on this site will bring up tons of posts regarding both parts. More than you probably care to read.
07-16-2020 12:54 PM
truedrew
R60/R61 Stock Problems/Issues
08-10-2015 10:39 AM
