Just turn the engine over using the starter connector on the right side of the engine bay firewall. Jump the white wire to power and it will crank. Make sure you are in neutral if a manual transmission.
Make sure you have the pedal to the floor to open the throttle plate. The only thing I have ever done is disconnect the coils, 5 seconds cranking per cylinder is all it took to get reliable readings. That's 20 seconds and your done, it doesn't have to be a chore.
There is but it is not as easy. 1 wire in the large round connector on the drivers side harness can be jumped. I cannot recall the color at the moment but sure you can find it on the wiring diagram.
