R56 can an OBD reader help?
The readers can see some faults that are caused by an HPFP or timing chain issue. Sometimes a dying HPFP will throw out the "fuel pressure not in spec" error, but often it won't.
Usually a bad tensioner won't give any error codes, though. Occasionally you'll see VANOS-related ones other other valve-timing ones, but it seems like the most common ways to find the chain tension problem are by listening for the "death rattle", or by having the engine jump time or the chain completely fail. You'll see error codes at that point, but it's rather too late then...
I monitor the Fuel Rail using the Torque app. I believe the Fuel Rail is showing me the fuel pressure delivered by the HPFP. I'm not an expert so maybe someone more knowledgeable can confirm.
The gauge shows app. 700 psi at idle but I'm not sure at other RPM's. I'm thinking I should chart the pressure at various engine speeds to give me a baseline to compare if I begin having problems.
R50/53 Help please.. Odd issue.
PsychoRallye
21
02-17-2019 06:08 AM
