R56 Catch Can suggestion
I have already installed a BSH catch can on my car with the recommended block off adapter etc. But I am still getting oil in the turbo intake hose. And the can typically traps very little oil. When I have emptied it; it contains more water from condensation in the lines than oil.
Is there another brand of catch can that will trap more oil? Thanks.
I found this style can after a thorough search.
http://www.mc2magazine.com/General_S...nturbo&pID=367
I really like the information provided on the "two Stage" oil filtering process. My BSH can does not have any media in it to trap smaller particles. It only has a metal baffle which in my case really isn't pulling the oil out.
Does anyone have experience with the above MC2 catch can?
on
It's not letting me load that page at work. :p
One I'm looking at that might have a decent setup for trapping is from http://www.saikoumichi.com/. Click on the top "The Design" page to see how it's setup. I think he redid the website as it doesn't show an active one for the MINI, but there is a line for a MINI Dual OCC on the right he might be working on. Edit: I've sent them an e-mail to confirm if they still have options for us, etc.
Based on what I've seen so far overall the other two I'm looking at with that one are the M7 & Madness Motor Works cans. The BHC struck me as large and I've read some folks have had quality issues with the baffle.
I'll have to check out that other one when I get off work.
on
Odd indeed. When I originally came across a Google for them they had a single can on a different page setup last week. Now it seems it's just the one above and it just mentions a double can. I'd rather prefer a single as well if it does the job, less space and hassle.
Let us know which one you end up going with.
Here's the reply I got back from SM:
Hey!
Sure thing! I had a bunch of guys order duals for the R56, but I have also had requests for the N18 which is using a single tank setup.
So the specs for that one is, S1-OCC base tank with 3/4" OD tube fittings. Default rotations.
I include an L-bracket for that one instead of the regular offset clip. It seems to be more useful.
Pics attached
Here is a quick quote. I forgot if you had a US address, but I can update that if necessary.
S1-OCC $85
US postage $11
My backlog is pretty long right now, unfortunately it is around 5+ weeks to build and ship.
Hey!
Pics attached
S1-OCC $85
US postage $11
on
Hey!
Pics attached
S1-OCC $85
US postage $11
Hey!
Pics attached
S1-OCC $85
US postage $11
You can expect the oil to go through the PCV hose that connects to the turbo inlet when you block off the only other PCV hose. You're going to be ingesting oil in at least one of the PCV ports, I choose the shortcut. You have oil in your intercooler and probably the entire intake tract, the BSH is a joke and like most have stated there's little media to actually catch oil.
I sold mine as there's nothing trapping the oil, oil in my turbo inlet PCV hose, I wouldn't be surprised if I had oil in my intercooler. I'll just get a walnut media blast every 30k-40k.
I'll agree, the Saikou Michi can has a good design. I like the fact that the vapor enters the can and is then drawn back up through the media. But, as far as the pipe size goes (19mm); hoses here in the states are still sold in SAE sizes, 1/2", 5/16 etc. Still can't access the MC2 site so I'll probably be ordering the Saikou Michi can (5 week wait time) once I get my car back from the dealer and can confirm the size of the PCV hoses I'm currently using for the BSH can (major Joke of a design). I was also considering adding some stainless steel media to the BSH but the problem becomes "How much" to add so it functions optimally but does not restrict air flow too much through the PCV system.
What's the simplest way to clean out the intercooler? The ALTA piece was such a PITA to put in; I'm dreading getting to the hose clamps etc to remove them.
Don't waste your time guys. The intercooler in my car at 60+K did not have any oil in the intercooler. My charge pipes had a thin layer of oil, but no liquid came out of the stock intercooler when I replaced mine. Now I have an OCC, and it doesn't catch much, but my charge pipes are now bone dry. I did NOT seal off the rear pcv.
I like the Wagner FMIC. Looks like it mounts with factory hardware and the inlet and outlet pipes are in the factory location and uses the factory hardware as well. Please confirm. Thanks If so, it may be time to replace the ATLA unit and clean everything out at that same time.
At least, that's my conclusion. There are others out there who disagree. I'm on my 3rd valve cover in less than 6 months, and can't believe I've had that many "out-of-box" faulty PCV systems. I can't find any reliable sources for N14 PCV DETAILED description, other than the Bentley manual, and I consider that just basic info. I'm afraid to re-connect the rear PCV line to my Saiku-Michi dual OCC, because I also believe my 30PSI boost is what caused the first 2 valve cover PCV failures. I'm still trying different PCV / OCC connections and other fixes, so nothing is for sure --- yet.
Anyhow, consider this and make your own determination, based on where the oil is coming from. There's a good chance that just driving with boost more often will stop the oil burning.
You nailed it with your last sentence. I chose the shortcut, the throttle body PCV hose/port. You'll never stop the black oily gunk from going into your engine unless you vent to atmosphere. Just have the valves cleaned every 40-60k.
It looks like the MC2 site is back up. It appears they upgraded to a new interface recently and that's why it had been down for a couple days. But the link works again:
http://www.mc2magazine.com/MC2_Oil_C...n.cfm?sc1=10,8
The MC2 can looks to be a superior design compared to some others.
I like the concept of the MC2 can but given the price point; I am fairly certain I'll be ordering the Saikou Michi unit as I don't need all the adapters that come with the MC2 since I already have those with the BSH unit. Just need to confirm the hose size with Saikou Michi for inlet and outlet barbs now that my car is back home. Just need to wait 5 weeks to get the new one. That part sux!!
