R56 Project Mini
Project Mini
Ok I might sound like a newbie, so I apologize in advance.
I have a 08 MCS and looking to get some more power by more power I want to get into the mid to high 300's. I have been looking into getting a ATP gt28 turbo kit, but not sure if that's the right route. Below are the current motor upgrades I have in my mini.
Now with the Alta Access port I was running stage 3 91oct but, for some reason my boost would cut off when flooring the car. So I have tuned it to Stage 2 but now having the same problem (not as bad) . Any ideas or suggestions on reason for the boost cut off would be appreciated.
But really whats the best route to go in my situation for more power.
- Akrapovic Turbo Downpipe
- Borla Cat Back
- Forge FMIC
- DDM Race Intake
- Alta Access Port
- Borla Cat Back
- Forge FMIC
- DDM Race Intake
- Alta Access Port
3in turbo back
bigger injectors(550cc)
better BPV(the stock one will not last)
bigger radiator
better radiator fans
oil cooler(this might not be necessary but id install one just in case)
clutch & Flywheel(Exedy stage 2)
HD CMC and Slave Cylinder(again might not be necessary but the clutch might be too much for the stock hydraulics)
LSD(to put down the power)
There might be more i am not thinking of that you might need but that should be the majority of what you would need to swap in a GT28RS, although if you are gonna do all that, might as well go bigger, a 16g MHI or maybe a 18g MHI turbo
- Borla Cat Back
- Forge FMIC
- DDM Race Intake
- Alta Access Port
You can forget about 300 hp with the stock bottom end, modded GP2's don't even get close to 300 hp unless you're spending serious money and happen to know a person that can push things further. You'll like the Akrapovic downpipe and the Borla Cat Back exhaust, they make a good match for each other. I purchase my Borla S-Type exhaust once I heard it used with the Akrapovic downpipe or any other catless downpipe!
- Borla Cat Back
- Forge FMIC
- DDM Race Intake
- Alta Access Port
Do you have a clutch that will hold this power? What about the axles, are they strong enough to hold as well?
I would look at the links below as a guide for your project if you're serious about reaching somewhat close to your power goals:
http://www.minitorque.com/forum/f272...nls-r56-25947/
http://www.minitorque.com/forum/f272/ducks-mcs-17554/
Not saying 300+hp isn't possible but it takes a lot of work. Keep in mind this is a 1.6l 4 cylinder you're talking about. That kind of power won't be achieved on stock internals either. You will have to build your engine and you probably will need custom parts. Custom big head, new cams, probably custom injectors, gaskets, and probably custom pistons and boring out the cyclinders to bring the car to a 1.8 or 2 liter. Then you need to figure out who will be able to tune for those things. Alta and that Accessport aren't going to be the solution for your goals. Look to JM Turbo Coopers for your Turbo. They have a K04 turbo that is a much better option than that Garrett turbo. You'll also need a 3" catless downpipe and a much more efficient intake than the DDM. Might even have to get a custom intake as well. You will for sure need an oil cooler and probably methanol injection. New spark plugs/ignition coils as well.
- Borla Cat Back
- Forge FMIC
- DDM Race Intake
- Alta Access Port
the mods you've listed will support Stage 1 with a FMIC at best .. anything more than that an your putting a strain on your turbo as its trying to produce more boost than it can
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
01-30-2021 01:35 AM
marendt428
08-08-2015 04:44 AM
PelicanParts.com
08-07-2015 08:39 AM
