R56 Justa reliability ?
Justa reliability ?
I read all these horror stories about the R56S and I guess I'm glad I sold ours and got a 135i instead
now that I have a longer commute I need a daily driver, 100 miles a day makes me look at picking up a r56 justa I don't want to put miles on the 135i or jeep.
Does the justa "ep6" ? have these reliability issues too? There is so much focus on the n14/n18 it's hard to determine what are shared issues.
I'm considering 08-13 anything on the justa that changed in 11?
I would get another S, but only if there are "bulletproof" mods that fix the shortfalls, and I do not think there are just yet, 26k miles a year is quite a bit on a turbo with "known" issues, one DI bmw in the garage is enough I think.
I'm on my third Justa. The first was a 2006 R50, the second was a 2010 R56, and I now have a 2012 Countryman. All have been very reliable, and a blast to drive. The issues with carbon build-up, high pressure fuel pumps, timing chain guides/tensioners, and turbo oil line leaks are all related to the S models.
'09 R56 Cooper Automatic here. Got it @13k miles, now 60k. Dead reliable. I have done all recommended maintenance plus oil changes every 5k miles. I have not modified the running bits in any way. Comparing to other cars and trucks I've owned - this car has been the most trouble free for its milage and age plus has provided by far the most smiles.
Front brakes @ 25k, fronts and rears @ 50k.
2007 R56 here. I had a problem with the climate control right after delivery which was fixed under warranty. At 60K miles I had a problem with the water pump thermostat - which did not strand me. Overall I consider mine to be quite reliable. Now at 74K miles. Speculation on my part, but I believe the engine is very sensitive to maintaining oil level at the full mark to reduce timing chain/tensioner issues.
I have an 08 R56 Justa I bought with 28,000 from original owner. I now have 61k plus and have only done brakes, plugs and standard maintenance every 5,000. I've had it a year and a half and we've driven it all over the US. Average 35 mpg mostly with my foot in it. Premium gas is a must for me. Wife has a 07 R52 Justa and there is no comparison as far as MPG or the ability to pass someone. The 5 speed compared to the 6 is not desirable for me as well. Luckily she only drives hers to work and she loves it. Great little vehicles and will prolly drive these two till they drop.
I would also add they don't have the high heat built up under the hood. With less power, the stress and wear rate on the engine and transmission is considerably lower. I totally agree they are a blast to drive and I have also owned 2007 MCS.
Morris, 2011 MC, PW/B MT
worst issue i think i've had on mine so far was a small oil leak at the front crankshaft seal. that was fixed for less than $200 f i recall. After that , the vanos solenoid was starting to fail so i was popping codes. i forget the cost of that. In any case, i'm at 64k and yet to have a full on break down type issue, always small things that weren't critical.(knock on wood)
Hope you are all OK. Will the car be repaired or replaced? :-(
