R56 R56 HPFP how to???
R56 HPFP how to???
I guys,
I've done a fair bit of searching and couldn't find anything, apologies if I've overlooked something.
Does anyone know if there is a DIY/how to write up on changing the HPFP on a R56 cooper s?
Has anyone done one themselves and did it take long/was it difficult.
Many thanks in advance.
Dane
Dane
Thanks for your reply.
That explains why there isn't any posts on it, because they're covered under warranty!
I should have mentioned I live in sydney Australia and unfortunately MINI Australia haven't been as kind with their extended warranty :( I'll have to get it fixed at my expense.
Dane
Dane
The warranty is limited to 120k miles. Mine failed only about 2,000 miles before that. But yeah, for the US with the extended warranty I don't think anyone has had to resort to passing for the repair yet, thus no DIYs.
I don't have it handy, but I do think replacement is covered in the Bentley manual. Could also try Pelican Parts - they have some good DIY guides, just not sure they'd have one for this.
If the towing charge is too much, I'd look into renting a truck and trailer to get it there. Just the part is like $800-$900.
Thanks for your reply. That explains why there isn't any posts on it, because they're covered under warranty! I should have mentioned I live in sydney Australia and unfortunately MINI Australia haven't been as kind with their extended warranty :( I'll have to get it fixed at my expense. Dane
I'm in Australia as well bought my car second hand read about the timing chains failing so rung up the closes MINI dealer and asked if it had been replace under warranty and the nice man on the phone said yes. Well you can imagine my delight and asked when was it done because all repairs come with a two year warranty, hold on there said the nice man on the phone were you the owner of the car when the repairs were done to which I answer was no, then NO ! warranty for you buddy said the nice man. Ah BMW always standing by their product and workmanship, well in Australia anyway. My advice buy the pump on line and install it yourself it will probably cost Quarter of what BMW will charge you !
All we really need is a tool to unclip the fuel line coming from the gas tank, it looks like it requires two pegs on top and bottom that need pushing it to get it off.
Looks like you put it on the fuel delivery line, lock it into place, and then disconnect the fuel delivery line.
The procedure looks somewhat involved, but not impossible to manage.
I can't find the MINI tool anywhere though.
I have the Bentley Publishers service manual, and they say that you're supposed to have the MINI special tool 13 0 250.
I just completed a major rebuild on my '07 MCS without this special tool. The HPFP input fuel line can be disconnected at the pump using only an open end wrench. No matter how it's disconnected, expect to mop up fuel. Replacing the line from the HPFP to the intake manifold is recommended by the Bentley manual, but others have re-used their old one without any problems. I suggest you remove (not just loosen) this coupling BEFORE removing the HPFP, to minimize any damage. It should be a comparatively simple task to DIY, if this is the only part being replaced.
Regards,
Systemlord.
Also installed a set of CP Carrillo rods and pistons, 10.5:1 CR & 77.0 bore --- no more fear of blowing them with >25PSI boost. Just finished break-in and starting to set the MBC. Last setting was 28PSI --- working up to 30. Not going for sustained boost, just quick bursts on the street --- so far! Eventually, I'll have it on a track (i.e., Thunder Hill Raceway) with several minutes of high boost.
Changed the valve cover again --- last Feb at Thunder Hill Raceway, my un-shielded turbo melted the valve cover, causing a serious oil leak. Fab'd a new partial shield, and added asbestos wrap to attempt a fix. Looks mickey-moused, but if it works ---
Thor56, keep us posted on your HPFP replacement --- who did it, how it went, tools used, etc.
I guys,
Dane
Dane
https://www.northamericanmotoring.com/forums/r56-hatch-talk-2007/273872-diy-hpfp-replacement-how-to-replace-high-pressure-fuel-pump-on-mini-cooper-r56-jcw.html
I have to do mine myself. 130k so no warranty and it's the second one.
Re linked it for you: the link was not clickable. At the end I linked the other HPFP that cam into affect in N18 13517592429 up to 3/2012 . The N14 one is 13517588879
https://www.northamericanmotoring.co...r-r56-jcw.html
Colt45Magnus
09-14-2015 03:12 AM
