R56 JM Turbo Coopers the real deal?
Hello all,
recently I have been doing my research to see what kind of items and products JM Turbo Coopers have been producing and it seems to me that it looks like they might be making quality products for all sort of MINIs. Please let me know if any of you have been working with them or bought products from them, I am curious about them. Thanks!
Here's their website, and they're based from Arizona!
http://www.jmturbocoopers.com/default.html
They seem legit IMO. I asked them about the R56 and turbo upgrades and this is what I got.
250hp is easily achieved by an
aftermarket intake, our inter-cooler, our biggest turbocharger, our
exhaust and our tune. We have seen a 25whp to 30whp increase just by
adding one of our turbos. One of our customers with a JCW and only
an intake and S42HP is pushing 215whp (247hp) and after our r34x he
was pushing 245whp (277hp). This was all done without retuning the
ECU (he does have JCW tune).
To answer your question The biggest
turbo we offer is the E45HP and the E45R. The E45HP is our quick
spool K03 and the E45R is our high flow K04. The E45HP doesn't
require any tuning to see more HP but if you want to see a
substantial difference it is recommended. The E45R does require a
tune unless you have our R35x 4” exhaust then it will spool up
quick enough to prevent a boost deviation error. However if you want
to see big HP than it tuning is recommended.
As you may already know the OEM 37mm
turbo and restrictive intake and exhaust system on the mini restricts
your air flow to 12psi. And when you reach the high RPMs the torque
really drops off. Before upgrading our R56 we could only get 12psi
at 2000rpms but about 5k it started to drop to 9psi. Even after we
upgraded the turbo we could only hold 12 psi through the RPM range.
Even if we tuned the ECU to 19 it would jump up to 19 then start to
drop back down to 12 at 4000rpms. Once we upgraded the intake and
exhaust we could hold just about any boost pressure we wanted at any
RPMS. In fact after installing our SRI (short ram intake), S42HP,
and R34x exhaust we were reaching 15psi at 3000rpms to 6000rpms with
no tuning.
We also can maintain a high level of
reliability since we are not changing the OEM designs other than
making them larger to flow better. Even with our turbochargers we
don't change them in any way but by changing the turbine sizes and
adding a 360 bearing. All of our upgrades are interchangeable with
the OEM units, so you shouldn't have any issues with them as long as
you follow our installation recommendations.
Any way if you want 250whp here is what
you need
E45HP (if yo do street driving or
commuting) or E45R (if you do a lot of racing, track, or highway
driving)
Quick spool K03
http://www.jmturbocoopers.com/JMTC--Extreme-45-K0-3-Turbo.html
High flow K04 (fore sale 4/15/13)
http://www.jmturbocoopers.com/JMTC-E45R-K04-Turbo.html
Aftermarket Intake
Short Ram Intake
(still under development due 4/3/13) we remove the restrictive 4 feet
of intake pipe and replace it with an 8 inch intake pipe. I have it
on my personal car and love it because you can hear the turbo spool
and the BOV open. Although I think my gas mileage dropped because I
love to hear the turbo spool up, it sounds like a jet taking off when
I am making boost.
Inter-cooler
http://www.jmturbocoopers.com/N14-N18-Intercooler.html
Needed for high boost to prevent heat saturation of the intake system
and keeps incoming air cooler (= more power).
Exhaust
http://www.jmturbocoopers.com/R34X.html
(do you need 4” maybe not, do you want it oh ya!) the reason we
offer the 4” is because even a 3” catalytic converter will slow
the air speed reducing power. So we do our best to maximize the air
flow through the exhaust so we give you a 3 in 4 out catalytic
converter. For the off-road cars we offer a full cat delete.
Dyno or remote tune
We don't have this
on the website just yet but is available.
Please feel free
to contact us if you have any questions or need more information. We
will be happy to help you build your car to output the HP you want.
Thank you
Arric Johnson
support@jmturbocoopers.com
480-559-5401
no tuning.
you need
driving)
Quick spool K03
Aftermarket Intake
Short Ram Intake
I am making boost.
Inter-cooler
Exhaust
Dyno or remote tune
We don't have this
Please feel free
Thank you
Arric Johnson
480-559-5401
I am curious because maybe later down the road, I might get a bigger turbo, but for now I think I will live with the OEM one.
I think their FMIC is a decent design for those who don't want to pay so much!
I am curious however about their O2 sensor for getting rid of the CEL for a downpipe and their tune if it's good enough.
I will shoot them a call in a bit to find out more information on some particular products I like from their selection.
Hi
I send email to Arric Johnsson/JM turbo coopers and asked a variety of turbo options to my MCS -07.He told the specifics of the options when I inquired about his construction of turbo.I definitely want turbocharger which reacts very quickly without no lag!He recommended S42HP turbo and at the same time I supply them the N18 exhaust manifold to ported.Quality of work was very good! Nothing trouble on installion,just "bolt on".They also provided the necessary seals and other components, such as a new oil pipe to turbo.I've driven with this setup about 4 months and n.5000 km without any proplems! The car runs very good,my turbo version is"Quick spool". Turbo raise the pressure rapidly,no lag, and keeps boost pressure high to redline.My full setup is S42hp,N18 ported exh.manifold,Akra downpipe,Forge fmic and bov,KN filter and Tune.Sorry,no dyno documents yet!.But anyway I recommend Jm turbo coopers,I had a good feel for how they work and served,delivery and shipping to Finland was fast!
Unfortunately, until JM posts some dyno sheets, I am very skeptical. I have talked with RMW about it, and they are saying these turbos will put me into limp mode often. NEED DYNOS from the manufacturer! Although, I am very interested in their short ram intake; whenever they actually release it anyway.
Hi
Any codes from the running the hybrid?
Here is a photo of their intercooler for $599.00 from their website.
http://www.jmturbocoopers.com/N14-N1...er-Cooper.html
It looks like the exact photo from a Ebay "from China" intercooler for $295
http://www.ebay.com/itm/Huge-FRONT-m...88487a&vxp=mtr
Well i have their 45R ported turbo, and I don't go into limp mode and the turbo really kicks in at about 2,000rpm. I don't know why RMW is saying it will go into limp mode. I never went into limp mode even with the stock turbo at 22psi. My tune is from PAW and PAW also had my motor built with cams, mahle pistons, port and polish, porting matching, 2.5" catless exhaust, renstiell DP, intercooler is from PAW intake from NM, and Forge DV oh.... and balanced crank. the car is my daily driver and with no problems. and by the way, for those that say the auto trans won't hold well it does and the tune from PAW is a progressive tune and this turbo keeps it's boost till I pass redline 6200rpm. the car is an 09 34,500miles on her and I had the engine done complete at 27,600
Any questions please PM me. I'll be happy to answer any questions. I dynoed at 257WHP at 21.7psi
No boost controller yet,now boost high peak is about 1.6 bar(23psi) but when I meet my "tunemaker" , I'm going to take it up.Last time when we meet,he told of the need to slightly modify the ignition timing form, in part due to the boost pressure lift.I think I can call it"custom made tune".
The only codes that have been, were before the turbo installation, and due to Akra high flow downpipe, no proplems after S42HP.
I don't mean to make fun, or start an argument. Just my $0.02
I think you should be at more power to the wheels than that. I'm at 255 on the stock turbo. I would kind of have an issue with only making 2hp more on the bigger turbo. Especially considering you have a built engine.
But with that said, different dyno's will show different results.
Compare a Dynojet to a Mustang and you'll see. Same cars on each dyno can see as much as a 20% difference in resulting numbers.
Taking 2 identical cars and factoring in height above sea level, humidity, which type of dyno you tested on, the tune and tuners ability, different transmissions, rotational mass of moving parts, temperature that particular day etc etc etc can all yield varying results.
One thing I would prefer to keep in mind is that a dyno is a tuning device, not an ego stroker. Don't go to the dyno to push big numbers and show of, go to the dyno to fine tune your setup. Don't compare your numbers to other people's cars, compare the to your cars previous numbers to judge your progress.
Back to the topic at hand.....
I bought a JM42 in June from JMTC. Arric was great to work with. Gets 2 thumbs up from me.
Unit bolted right on. Not sure about the concern RMW might have, but I would ask if the concern is with JM product or any aftermarket product?
I didn't get a tune after I replaced my JCW turbo, (it failed), I bought the JM42 because of the cost was less than an OEM JCW turbo. Mine runs fine. Spools like the OEM, maybe sooner maybe not. I just don't care enough to try see if I should **** for distance or **** for accuracy. :-)
Good replies to everyone who is posting their experiences with JM. I am currently looking at either rebuilding my factory JCW turbo, or getting a new turbo from JM. I really appreciate the good reviews from everyone. I am really just trying to get results from anybody who has gotten a JM turbo. RMW is advising me otherwise, but my turbo seals are starting to go. So why replace when you can upgrade on a rebuilt, right?
When RMW only has "it will throw codes and put you in limp mode" to deter you from it, and actual JMTC customers say that never happened, well there that goes... To me, if it's cheaper or even the same price to get a freshly built/rebuilt/inspected/warrantied bigger or better turbo, why the heck wouldn't ya? I'm planning on buying the single-mass conversion flywheel/clutch kit from them when my clutch bites the dust, and their turbo information and such seems pretty top notch to me. I wouldn't hesitate to take the chance on them.
I must say, I enjoy your input in any forum. That aside, I agree. If people who actually have the product enjoy what they bought and believe it to be good value then I think that is what counts. I also am doing one of JM's clutch kit conversions when my DMF and clutch kick the bucket. I think this is more of a leap in terms of the quality of JM's product and service. OS Giken is the only proven clutch kit, but JM's kits seem like they would work. I wonder if any one has any experience with JM's clutch kits that wouldn't mind imparting their thoughts...
