R56 NHSTA MINI 2007- 2011 Recall
#77
#78
#79
So much for the resale value of almost every vehicle on the road. I guess this explains why the dealer offered me so little for my Ford F150, what with that super scary recall of the wiring harness for my airbag. Or maybe because it was a POS gas guzzling Ford....I dunno, I'm liking your logic.
#81
#84
Oh, sorry, it was in the notice on the recall from Canada which came out just slightly before the US one ... I did not notice they had not included that language in the US. The Canadian one says "Note: Owners are advised to park the vehicle outdoors until the remedy is applied."
#85
#87
#88
I would worry more about overheating my supercharger by disabling the auxiliary water pump! Leave it be and get the fix when you can.
https://www.northamericanmotoring.co...e-on-tach.html
#89
#90
Though, read the recall yourself and see if you agree. It's a quick read anyways and you get to understand a little bit more about this!
Useful links to read:
#91
I really don't have anywhere to park outside the garage where I can still get another vehicle out.
#92
cereal, those are superb references that should be mandatory reading for everyone to avoid much of the speculation and misinformation.
Two important facts are revealed (briefly noted by DaveJ):
1. The MINI aux water pump does not operate while the engine is running, and only kicks on when the engine is stopped. One might presume that the flow of air and lubricating oil is enough to control the temperature of the turbo while the engine is running. Also, since it's not drawing any current there is no reason to believe that this particular failure will happen while operating the vehicle (consistent with the individual NHTSA reports we've seen).
2. The MINI aux water pump only runs for a maximum of 15 minutes after engine shut down. This would appear to be the "threat period" when the circuit card in your MINI's aux water pump is vulnerable to the failure. It's easy to hear the pump running after one turns off the engine and, quite frankly, I've never heard my pump run that long. In my observations of my '11 the running time is typically closer to 5 minutes. This is a nice, short window of time to keep an eye (and a nose) on the situation just to be safe.
#93
I sometimes back out to wash and then pull back into the garage. I don't think the pump runs at all. That is what makes me think a driveway cool down will be part of my plan.
#94
Ha! I just received a call from the NHTSA today in reference to a complaint I filed last July about the electric power steering pump failure in my R53. The agent told me that they have hundreds of complaints and are looking to get the manufacturer to "do the right thing" on this one. Looks like BMW/MINI might have another big recall on their hands as well. I say it's about time as the damn thing nearly killed me when it failed! MINI really should step up and fix known problems like these. I hope they learn a lesson for the future from all of this, but somehow I doubt it.
#95
If you read item #6 starting on page 2, you will see that BMW created a task force in July 2010 to investigate the electro-migration issue. It further goes on to state that in Nov 2010 they confirmed the root cause of the circuit board and water pump overheating failures. However, their action (or rather their inaction) only consisted of continuing to monitor the field (i.e. the cars that have been sold).
It is only after the NHTSA opens an investigation on October 11, 2011 and sends BMW a request for information on October 18, 2011 and an amended request on November 14, 2011 does it appear that BMW apparently get motivated to in December 2011 complete the "final testing and analysis of the mini water pump [was completed]". Then, magically, "on January 3, 2012, BMW decided to conduct a voluntary recall".
#96
I usually go easy the last 2-3 miles just to let the turbo cool and I also have noticed that it only runs about 5 minutes max.
#99
Absolutely none. I didn't look or care about recalls when I bought mine and I certainly didn't care that the tailpipe recall wasn't even performed on my 07 MCS. Only time that a recall would have a any impact (in my opinion) is something similar to Toyota (denial of an issue for a really long time) or the Explorer (media blaming the explorer for a really long time). Even then, given a decent time period and the stigma is completely gone.
