R56 NM Engineering Lowering Springs for Mini Coooper R56 S
HI-
I purchased some lowering springs after countless hours of researching on which ones are the best ones on this site. So i went with the NM and I am here to report that everyone who cheered for these springs were dead on.
They do not have a bumpy ride (my first springs) and they acutally feel like stock or even better on bumps. I have don't many unoffical tests around corners and i can go around them 15 to 20 mph faster because it's so much more stable.
I did a video review from install to riding on them. If you want to check it out, here is the Youtube link http://www.youtube.com/watch?v=6sljEQTT1IM
If you're looking to get a set, get them at http://www.customcarscentral.com/ and ask for Dmitiri, he or someone there will hook you up. They have free shipping too.
Let me know your feedback please and thank you for your suggestions.
on
NM-Eng's site says it drops 1.2"
does this stay true, or how much do they settle and drop further?
am currently in the market for either the H&R or NM springs - just have a feeling the H&R might drop too far for my taste after they settle...
any advice would be greatly appreciated!
on
Good to hear!! You are gonan LOVE them!
Are you going to do the install yourself? I'd say it only took me half the day maybe less when i did mine. The only "special" tool i needed was a spring compressor which i rented from a local auto zone. Pretty easy install!
I'm going to order my "Autometer Boost/Vacuum Gauge: Mechanical" / "Atla - Mini R56 Single Gauge Pod" / and "NM eng. Boost Sensor Tap" today! Thoughts anyone?!?
Anyone have any idea if these Springs will work on a JCW Coupe? I'm in the market and keep hearing these springs are very good.
Also, when you say "snap oversteer", how much are you talking/how extreme and in what condition ie. are you pushing the car very hard when this occurs or is it just random?
http://new.minimania.com/web/Item/G2.../InvDetail.cfm
didnt think they'd be so pricey. Any differences with NM springs w/ Koni yellows vs some coilovers?
on
The snap over steer i have actually grown to like quite a lot. The turn in response is almost immediate!!! It’s not uncontrollable by any means. I could tell the difference the first time i turned a corner after installing the springs. I was used to it after a day or less of driving I'd say. And i imagine this could have been reduced if i had my camber adjusted after the install. Not gonna lie, i skipped that part of the install instructions. I liked how the car drove and handled so i never had the camber changed. In the NM engineering instructions at the very end they give you some values you can tell a shop to adjust your camber too. "Adjust to (some value) for stock feel, adjust to (some value) for more aggressive handling."
Just a question...would the koni yellows that everyone is talking about these?
Heard the Koni Yellows are a great compliment to the springs but also megan coilovers is a great company to buy.
But yes coilovers/shocks are expensive for a good set. havent seen anything really under $800 thats decent.
I don’t know for sure but i can’t see why the springs wouldn’t work with the JCW Coupe.
Thanks!
NM Eng Spring issues
Has anyone had issues with the NM engineering Rs springs bottoming out on the front? I have had mine on my car for almost a year now. For the most part, they are great. But once in a while I will a bump that will bottom out and hit violently. I replaced the springs, sway bar links, rear sway bar, when I did the work.
I did not replace the stock shocks or perform the camber alignment as suggested. My tires were old when when I put the springs on my 2010 MCS, and so I was going to wait to get this done with the new set of tires. I have not noticed any abnormal wear so far.
09R56
11-16-2022 10:49 AM
07-16-2020 12:54 PM
marendt428
08-08-2015 04:44 AM
