R55 Trying to make my 2009 clubman jcw faster
Vendor
The easiest and most cost effective would be an ECU tune
https://www.waymotorworks.com/perfor...-cooper-s.html
and also a Forge intercooler
https://www.waymotorworks.com/forge-...r-s-turbo.html
Then a Downpipe
https://www.waymotorworks.com/08-10-...mance/exhaust/
Then a Downpipe
I have a Clubman S with some modifications done to it. It is my daily driver so I wasn't looking for anything over the top. Just some things to make my commute more enjoyable.
StopTech front slotted rotors with EBC Greenstuff brake pads
K&N Intake w/ aftermarket Forge intake hose & charge pipes
A simple plug and play ECU
The engine mods gave a lot more life to the car and power. The brakes make up for the stopping distance that can now be quickly traveled.
For sure would love a down pipe and some suspension work but I don't plan on having the car much longer.
Hope this helps!
Hope this helps!
Moderator
My 2009 Clubman JCW is already a pretty fast car. What's your objective? Are you looking for bragging rights, or to impress? If so, go for the modifications. Just remember that your car is built more for the twisties than for drag racing...
Pardon me if I get a little preachy....but my Dad's father to son talk is ringing in my ears...even though it was a verrrry long time ago. It went something like this. If you want to just enjoy the car, maintain it well and work on learning how to drive it to get the most out of it. If you don't already know how to heal and toe, watch YouTube and practice......lots. Unlike so many other cars on the road, your MINI is set up perfectly to heal and toe.
The only modification that I would recommend at this point is-
https://www.waymotorworks.com/nm-eng...nt-insert.html
My reason for this mod is that it reinforces the connection between your right foot and the front tires....by reducing the amount of motion the engine goes through as you press on the throttle.
Driver training through the BMWCCA, SCCA, or other organizations would be a great thing to start planning now.
Soapbox is back in the closet....have fun and be safe.
Ditto on learning HOW to drive fast...
Having said that. By far and away the best way to make any car faster is to make it lighter (that includes the driver). Lighter wheels and tires is a great way to reduce weight and thus improve acceleration.
The $75 to Get one of these will change the dynamics of how the engine and trans put the power down. Great bang for your buck.
http://www.madnessmotorworks.com/mad...gine-bushings/
From there the next best way to actually make more power and torque is thru an ECM tune and more cold air. There are multiple ECM tunes available, most of which are specific to your current mods. Do your research and find one that meets YOUR needs.
More cold air in means more power for you. Get yourself one of these:
http://www.madnessmotorworks.com/min...7-r55-r58-r59/
The ALTA one does not fit very well, at all. The one above fits AWESOME and has more volume of air flow than the Alta one too.
You will want one of these, or something similar:
http://www.madnessmotorworks.com/mad...nd-jcw-models/
Again, more cold air in means more power for you. I have the AEM version. Do NOT use the heat shield that protects the hood scoop as it redirects the hot air from your turbo onto your valve cover; not good!
The ECM tuning is great, but will do very little if the engine can't get enough cold-air in AND out. Thus why an intake and exhaust make a huge difference. Dyno testing and other flow test have indicated that the aftermarket downpipes do very little and will more than likely cause an error code to show up. Your JCW lower intake, JCW exhaust, and JCW turbo will likely flow plenty of air for what your looking to do. The ram-air style intake makes a noticeable difference (at least in my case) when accelerating at speed. Opening up the small holes in the JCW air-scoop grill would help this as well.
As for saving money: look on Craigslist locally and on the "For Sale" section here on NAM. People are constantly buying, selling, upgrading, parts and selling off their old parts. Used bolt-on parts work just fine.
I got my NM wheels with really nice tires, an ALTA Front mount intercooler, NM boost tap, NM 22mm rear-sway bar, and an ALTA recirc-valve (which I never installed) from a local guy who was un-customizing his MINI. All of which cost me less than the price of buying and shipping the ALTA intercooler brand new. Oh, and on that note, never offer someone less than asking price until you are in front of them with CASH in hand. DON'T be THAT guy! Only negotiate/talk pricing when you have seen the part and met the seller. CASH talks, BS walks. Make your offer, show them the cash, and then SHUT UP. Let them think. Let them look at the money; even hold it. Humans don't want to hand the cash back to you. Oh, and bring a friend with you so that your safe. Best to meet in a public setting, blah blah blah...
Alongside suggestions of track days, check out autocross (aka Solo) in your area. It focuses more on quick direction changes like slaloms, reaching top speeds of maybe 50 mph in a small cone course with nothing to hit if you go beyond the car's limits. Aside from driving way crazier than you are allowed on the street, you learn about your car and what it can handle. I like to consider it training for emergency maneuvers.
Like absolutjh22 says, standard path to more power is intake, exhaust, intercooler, tune, and catless DP. Although I'm curious about that last opinion on negotiating. I do all my negotiation before meeting up and then it's a quick transaction to make sure product is as advertised.
