R55 Coding
Coding
I keep getting the following engine codes on my 12 clubman base...PO030, PO132 & P2414 Can anyone assist with what maybe causing these? Bad o2 sensor or something else? Also I thought I saw a post where Mini extended the warranty to 10years/100000mi on o2 sensors. Is this correct? I currently have roughly 76000mi on the car now.
Hi.. From the Bentley service manual, but I can't help to interpret them. Maybe others can hep with that part.
PO030
This has two MINI FCs of:
0x2A63 HO2S Heater Control circuit bank 1 sensor 1
0x2D0D HO2S Heater Control circuit bank 1 sensor 1
PO132
This has two different MINI FCs of:
0x2A98 O2 sensor circuit high voltage bank 1 sensor 1
0x2CFF O2 sensor circuit high voltage bank 1 sensor 1
P2414
This has two different entries with MINI FCs of:
Ox2ACB O2 sensor Oxygen sample error bank 1 sensor 1
Ox2CF8 Oxygen sense before catalytic converter, Installation: sensor is not installed correctly in the exhaust system
PO030
PO132
P2414
Although a Honda site, this doc shows emissions system parts coverage. http://owners.honda.com/Documentum/W...t/apl27540.pdf
Should be covered : https://www.northamericanmotoring.co...o2-sensor.html
