R55 Spark Plug Replacement
Old 11-30-2014, 11:10 AM
dkamp's Avatar
dkamp
dkamp is offline
I need help!!
I confirmed the correct plugs for my 2008 Clubman R55 with an N12 Engine is Mini# 12-12-0-035-933 and is Beru 12ZR6SP03
But cannot confirm the Plug socket needed.
I think it is a 12 Point 14mm (thin Wall)
Can anyone confirm?
Old 11-30-2014, 11:35 AM
DRoc7822's Avatar
DRoc7822
DRoc7822 is offline
If they are the same plugs as in the hardtop then yes the 12 point 14mm thin wall socket should work. I got mine off Amazon a while back.
Old 11-30-2014, 12:46 PM
ashchuckton's Avatar
ashchuckton
ashchuckton is offline
Old 11-30-2014, 05:03 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
Here is the socket you need:
http://www.waymotorworks.com/spark-p...-r59-mini.html
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
Old 12-01-2014, 12:59 PM
ashchuckton
Sure does look like the one linked earlier.
Old 12-07-2014, 03:32 PM
dkamp's Avatar
dkamp
dkamp is offline
I got the Spark Plug socket 14mm 12 point thin wall from eBay for $13.86 that includes shipping.
Worked great.
I put in the new plugs the specs say torque should be 20Nm.
Research showed this to be 14.75 Ft-lbs or 177 in-lbs.
The old plugs looked worn and great color.
The old plugs had a Gap that increased to almost 2mm (It should be 1mm).
Old 12-08-2014, 10:51 AM
ECSTuning is online now
Received 1,965 Likes on 1,765 Posts
Its right here and currently on sale, incorporates a magnetic ring that holds the plug when you take it out. Use it with a medium length 3/8th extension.
http://www.ecstuning.com/Search/SiteSearch/ES2561145/
And the N12 ( Cooper NON S ) Spark plugs right here. 12120035933
http://www.ecstuning.com/Search/SiteSearch/12120035933/
thanks
Old 12-08-2014, 02:49 PM
dkamp's Avatar
dkamp
dkamp is offline
Thank you ECSTuning.
Too late for this time but I will Book mark your site for my next job.
I am interested in the Service Manual ECS Part# ES#2216079
but it a little high for me. If a sale occurs please let me know.
Old 12-09-2014, 04:41 AM
Welcome,
We are priced well below most of the market, and we are one of the few with the newest Bentley manual B13 . If you area DIY 'r its a must. Plus its free ship. No current sale on these , they just came out.
http://www.ecstuning.com/Search/SiteSearch/ES2777802/
Old 12-09-2014, 12:50 PM
ashchuckton
If one wants a Bentley manual keep an eye on the marketplace they often show up at a good price.
Old 12-11-2014, 12:50 PM
R55&R60_N18's Avatar
R55&R60_N18
R55&R60_N18 is offline
I need spark plugs for R55/N18 - 2012 S CLUBMAN PLEASE =)
Old 12-11-2014, 01:26 PM
N18 2012 R55 Clubman S :
http://www.ecstuning.com/Mini-2012-Cooper-R55-S_Clubman-Coupe-L4_1.6L_N18B16A/Engine/Ignition/
Get that socket tool also linked above also.
Old 12-19-2014, 11:13 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Minnie.the.Moocher is offline
Welcome,
How useful would this manual be for a 2011 Countryman? I assume lots of it are similar.
Old 12-22-2014, 05:04 AM
Pretty useful as it has more N18 ( Cooper S / JCW ) engine and N16 ( Cooper ) engine MINI shared components from the R56 R57 R55. Does not have the 4 wheel drive talk, but some stuff is similar
Old 03-29-2015, 07:42 AM
Aelwulf's Avatar
Aelwulf
Aelwulf is offline
Anyone know if there are any tricks with the spark plug sockets? Got one from Way and it seems like it wants to grab but doesn't, like it's short.
Old 03-30-2015, 06:41 AM
Don't know about that socket. But the schwaben ones linked above goes in all the way in to catch the 12 point neck. Maybe you left a piece of metal or something in the that socket that blocked it ?
Old 03-30-2015, 11:45 AM
Aelwulf's Avatar
Aelwulf
Aelwulf is offline
I was looking at that one as I liked the potential for the magnetic bit, but you won't have it until early April according to the page. May have to give it a shot anyway.
It seems close in appearance et al to the Schwaben, just no magnetic hold. It uses 3 leaf springs of sorts to hold the plug instead. Nothing's in the well that I can see except the spark plug. When I put a bit of down pressure on it it seems to be turning but whenever I check the plug hasn't moved.
Old 03-30-2015, 11:44 PM
grussell's Avatar
grussell
grussell is offline
It definitely sounds like the socket is not going down far enough. Is the socket binding on the sides before it goes all the way down onto the plug?
Old 03-31-2015, 08:46 PM
Aelwulf's Avatar
Aelwulf
Aelwulf is offline
Not that I can tell. No problems in the tube, I think I can feel it snap at least partly on top of the spark plug. With some pressure it feels like it's catching something when turned but nothing actually happens. So only thing I can think of is a short socket. Or, somehow, long spark plugs?
Old 03-31-2015, 09:22 PM
grussell's Avatar
grussell
grussell is offline
The reason I ask is before I knew about a thin walled socket I used a regular one. It felt like it was seated on the spark plug and was a little difficult to turn, so I thought the plug threads may have been buggered up. What I discovered is the socket was not on the plug and I got that socket wedged in the hole and it was a bear to get it out. It was late at night and the wife needed the Mini the next morning to go to work. I found a set of 3 different size sockets at Walmart and one fit the Mini perfect.
Old 03-31-2015, 10:41 PM
Aelwulf's Avatar
Aelwulf
Aelwulf is offline
Oi! Sounds like a close call. Thanks for the tip. I tried a regular spark plug socket I have and it wouldn't even fit in the well. This one was ordered specifically for changing R56 plugs so I'd hope it'd be the right size. I'll probably end up ordering the other one from ECS in a few days when they're back in stock to compare.
Old 04-04-2015, 10:20 AM
scott13's Avatar
scott13
scott13 is offline
I would try putting a new spark plug into the socket you got and make sure that the 12 sided plug fits fully into the socket. I can't imagine that this socket will not work if it was sold specifically to work with our MINI's.
Old 04-06-2015, 06:26 AM
Aelwulf , did you get our new socket and try, I hope the head of the 12 point on the spark plug is not damaged either.
Old 04-07-2015, 11:33 PM
Aelwulf's Avatar
Aelwulf
Aelwulf is offline
Not yet, it's now showing not in stock until April 10th on your site.
scott13: Yeah, I'll be doing that once I get a chance. I'm hoping tomorrow night before kiddos have to hit the sack.
Old 04-08-2015, 09:15 PM
Aelwulf's Avatar
Aelwulf
Aelwulf is offline
Got a second to check it out in the garage this afternoon. The socket does indeed seem to be too short. Placed over one of the new Brisk plugs waiting to be installed it looked to be almost a half-inch too short to engage the plug to turn it. It's this socket:
ECS, could you link to the one you have for an R56 JCW with the N14 engine? The one linked above has once again pushed out shipping date to the 14th. I'd rather not order and play a waiting game with no discernible end point.
Thanks all for the input.
Edit: found out why it doesn't fit. Not sure what type of plug it is but it's not the typical shape for the socket. I had to get a 5/8" / 16mm to try and get them, and that would be needed for the new ones. I'm curious what plugs are in it since not stock.
Quick Reply: R55 Spark Plug Replacement
