lose of power
Old 12-04-2016, 03:45 PM
froggy_07's Avatar
froggy_07
froggy_07 is offline
lose of power
The other night i filled up on gas. 93 octane. SES came on and started sputtering. No power driving home. Took fuel cap off then put back on sputtering stop but SES was still on. still low on power and cooling fan doesnt turn on. slight smell of fuel and burnt rubber. Any suggestions?
Old 12-04-2016, 03:49 PM
froggy_07's Avatar
froggy_07
having a problem..it will not show the whole message. ok I shortened it now it shows.
Old 12-04-2016, 05:09 PM
froggy_07's Avatar
froggy_07
2007 Mini Cooper S
supercharged
~122k
Old 12-04-2016, 05:10 PM
froggy_07's Avatar
froggy_07
Old 12-04-2016, 05:11 PM
froggy_07's Avatar
froggy_07
I drove home (
Old 12-07-2016, 07:17 AM
ECSTuning is online now
Received 1,964 Likes on 1,764 Posts
Read it with a good scan tool first otherwise its a shot in the dark.
https://www.northamericanmotoring.co...d-q-and-a.html
Old 12-07-2016, 11:51 AM
froggy_07's Avatar
froggy_07
was a misfire on cylinder #1.
Old 12-07-2016, 11:52 AM
Coil Pack connection wire most of the time when its just one cylinder, then check the plug itself. Then Change out the coil pack.
Old 12-07-2016, 11:55 AM
froggy_07's Avatar
froggy_07
i had plugs and wires done within 6 months ago. Maybe a fuel injector is dirty?
Old 12-07-2016, 12:01 PM
froggy_07's Avatar
froggy_07
sorry about that i sent that message before I saw yours show up
Old 12-08-2016, 02:09 PM
nkfry's Avatar
nkfry
nkfry is offline
Check the torque on the plugs, make sure there isn't gobs of anti seize or dielectric on everything.
If it started right after fueling up I would caution a guess to the quality of fuel. Are you sure you didn't fill up with E85?
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old 12-09-2016, 07:06 AM
No problem. Did you ever scan it? Also make sure the wire and plugs are tight and snapped in all the way, as well as the spark plugs. They can work themselves out. Also with a good scan it would tell you if the injector is firing. A quick way to check that is to unplug that wire harness plug to it.
Old 12-09-2016, 07:03 PM
froggy_07's Avatar
froggy_07
I always use E92.
Old 12-09-2016, 07:05 PM
froggy_07's Avatar
froggy_07
ECS I did have it scanned, misfire cylinder #1.
What happens when evap leak occurs? (fuel cap not sealed) SES light comes on.
Old 12-09-2016, 07:08 PM
froggy_07's Avatar
froggy_07
Ill check the wires tomorrow and see what I can find.
