R52 Oil Change
Old 08-15-2015, 11:20 AM
Laura Redd Casler's Avatar
Laura Redd Casler
Laura Redd Casler is offline
Oil Change
I removed the Oil filter cap and reinstalled due to a minor leak around edge between the cap and the housing. After carefully reinstalling the oil filter cap, the leak is much worse. It is a solid stream between the cap and the housing. I have the filter properly oriented, the rubber gasket in the right place and oiled and it is not cross threaded. I can see no visible cracks.
Old 08-15-2015, 06:39 PM
05r50's Avatar
05r50
05r50 is offline
Sounds like the gasket has torn or you are not tightening it down enough.
Old 08-15-2015, 09:32 PM
ZippyNH's Avatar
ZippyNH
ZippyNH is offline
bet the gasket is bad...
aftermarket filter?
I always like the OEM Mini, the MANN(one of 2 oem filter makers) was usually my choice...
get a new filter...toss it out if you want, or swap it..put in the o-ring...lube it up, and install...should be about $8-12 or so...if a place tries to sell it to you more much more, RUN. There are stories of places selling no name junk for $50+.
should be able to tighten it down...check for leaks....
Kimolaoha
07-05-2023 01:04 PM
woodstudio
03-15-2020 08:28 AM
Colt45Magnus
07-14-2019 06:18 PM
patpatpat
08-27-2015 07:51 AM
HaveATank
08-24-2015 10:26 AM
Quick Reply: R52 Oil Change
