R52 Power Steering Cooling Fan Question
Hello,
Here is a thread with some more info on the power steering fan. The older original ones don't have the little built in fuse/ resistor. Newer ones do. They all get the newer one when replaced. We have some options here:
https://www.northamericanmotoring.co...ng-issues.html
You can buy a "bare" fan....and reuse the metal part....
Later 2005+ mini's had the fans screwed on...yours is likely rivited on...drill them out, and use 4 sheet metal screws to mount the new one....about 5 minutes...
IMO buy a fan with the box...mine was the same...bet the box is a thermal fuse of some types...early minis seem to have s FIRE issue...but changes in mid 2005 seemed to fix the issue....
You are welcome. Read through my link above and check everything out while you are in there. Good maintenance to check things out.
07-16-2020 12:54 PM
JPMontes3
08-23-2015 01:26 AM
Etrain
14
08-20-2015 10:32 AM
minipopkart
08-13-2015 05:22 AM
