R52 Buying a former wrecked MINI, maybe
Buying a former wrecked MINI!
Hey folks, I've been hunting for the last couple months and found what looks like a good deal, but thought I'd ask you experts if there is anything in particular I should look out for.
This is an '08 S manual convertible with very low miles (what I've been looking for). It has a salvage title, the guy buys a lot of wrecked cars and fixes them up, drives them and sells them. He's in the middle of nowhere and not near any MINI or BMW shop. I will insist that we go about 30 miles away to get it up on a lift so I can look carefully underneath.
I've done a lot of research and know the typical things to look for, but this car was rear ended on the driver side. The dealer tells me that you can't tell, cosmetically (which I don't care too much), and he said there was no frame damage, the car drives straight. He says the only issue is that the airbag light came on when someone put it on a lift to repair the exhaust.
I plan to rent a car and drive several hours to go check it out on Monday or Tuesday. I know I'll need to make sure the top works well, and of course see how it drives, check the usual things like motor mounts, oil leaks, bushings, etc., but anything else?
He wants about $3K - $5K less than it would be if it had never been wrecked (marked on title). I'm not too worried about resale value, I plan to drive it into the ground. And I'm hoping that will take a long time.
The common discount for an accident is about 30%. For salvage it is more. Salvage means the car was written off so it had to be pretty bad, more than just a bumper and corner. Salvage is a whole other deal IMHO especially if a flood car. I think I would pass.
Don't believe the BS about the airbag light. The common failure for the airbag is the passenger seat and the fix is VERY expensive. Like $1200 or more just for that. Putting a car on a lift has nothing to do with the airbag unless they dropped it from the lift.
Thanks for the replies and opinions. Looks like it has never flooded. I'm going to check it out tomorrow. His wife has driven it 2K miles since the repair, so the original tires might indicate if it's got alignment issues. He claims it should not have been a salvage vehicle.
If anyone has more info about the airbag light, please respond. I will research if I get a chance. I'm taking it to a mechanic who should be able to read the codes, can the light maybe be reset? If it's on, will the airbag not deploy? Sorry, I don't know much about airbags, as I've driven mostly old cars.
I'm really thinking I can tell if there is any significant damage by driving it and looking underneath, carefully, and maybe checking the alignment on a machine.
The way I look at it, if it checks out, I will save $5,000 and if I keep it for a long time, will come out ahead in the end.
Salvage= totaled....
Anybody who thinks they can fix cars cheaper than insurance companies calculate it will cost to fix without CUTTING SOME MAJOR CORNORS is crazy unless they are working for free....
Body shops do insurance jobs at DEEPLY discounted rates, most can use salvage parts, and fix cars to be as safe as BEFORE THE WRECK....
Now if you don't mind driving around him a death trap....it might not be insurable in some cases....go for it....
I would run....
His story about an airbag light coming on during exaust work is either a complete lie at best, or points to a possible wiring issue ....sure could be a $900 seat bottom.... But could be a chafed wire from the body flexing....
One more tip....
Modern cars have NO FRAMES... some pickup trucks and body on frame SUV'S, but not cars... Cars are UNIBODY....that could BE BENT TO HELL...BUT BY SAYING NO FRAME DAMAGE, HE CANNOT BE SUED...cause there is no frame....
Sounds like a slick fella....
I would run....
One more tip....
I know you're probably right. I get the feeling this guy is honest, but I will do what I can to verify it. I must check it out, in the case that it's a great deal. I've test driven several and think I should be able to tell by watching it drive, driving it and looking it over carefully with a mechanic if there's any real problems. I will probably get him to know a grand off because of the airbag light.
I just can't pass up the possibility that I might get the car I want with 11K miles and $5 or $6K below a comparable (non-wrecked) one.
I am not sane, by the way.
Just exactly how cheap is this MINI? It would have to be really cheap before I would even think about it. The whole reason there are salvaged titles now a days is because of people buying them and just patching them together and doing a shabby job.. Most would make them look good but rarely pay any attention to the hidden damage like the unibody under carriage..
Something tells me you just want this car! ha ha.. The only thing I can say is go into this very cautious.. that's really the best advice one could give.. Ive done a few repairables. But that was years ago when you could pick them up reasonable then.. There just is no money in it once they stared to stamp the titles. Look it over good because once you buy it..its your baby.. I would bring your "A" game and beat him up on the price as much as you can..good luck! keep us posted on what you do! Cheers!
Well, I bought it. Test drove it and looked it over closely while on a lift. Had it hooked up to a machine and everything checked out, including the airbag (reset and the light has not come back on).
The car seems brand new. Very little damage, besides a dent in the muffler that you can't see unless it's in the air and it doesn't seem to affect the performance.
Drove it home 7 hours, the first half pretty aggressively through the Ozark hills. It did great. I am very happy and feel like I got a great deal.
If there are any new developments, I will add them to this thread.
Wohnson89
06-10-2020 04:53 AM
arf88
05-31-2016 03:07 PM
Navigation & Audio Aftermarket In-Dash Navigation
kitty90034
Navigation and Audio
08-25-2015 12:47 PM
