R52 HELP Technical assistance needed
Fairly new to the Forum, as I only recently purchased my 2006 Mini Cooper Convertible (Auto). I was working on my car last weekend on my drive, actually just fitting a new Hood stripe and Side Decal. When completed I got in the car turned the key, ABSOUTELY NOTHING happened, apart from a clicking sound from within the drivers door. The only lights to come on were the Airbag light and the convertible top lights located at the top of the windscreen surround. Not been able to start it since then.
Hope to get the battery & alternator checked tomorrow, BUT failing that, and me knowing little about these BMW Minis, looks like an auto electricians job to me. If anyone can give me a clue, it would be much appreciated. Also which would also be of help would be any recommended contacts for a Houston Mobile Auto Electrician. I am located in the Route 6/Lille York area of the town. Any help would be much appreciated.
Thanks for the Feedback
I also thought it MAY have been some peculiar Mini thing ?????
Thanks again
MY Guess...
The battery was weak...
And sitting (maybe with the radio on) doing the stripe install was the last straw....
I'd test it first....
A jump might take a few minutes...folks sometime make the mistake of trying to crank as soon as they hookup....but with a flat battery soaking up the current, it MAY take 5 or 10 minutes depending on the guage of the jumper cables, to get a start....
I'm assuming your battery is the original from 2006. Even if it will hold enough charge to turn the engine over, do you want to trust it to not strand you somewhere? In my case, I was actually parked at an AutoZone store buying another part when I got the click-click-click death rattle. They tested the battery right there and I bought a new one as a result of negative test results. Couldn't believe the luck ....
THANKS guys for the assistance, This is what car clubs are all about, helping each other. GREAT STUFF,
07-16-2020 12:54 PM
Drivetrain Help on MAF Sensor Clip - Cannot Remove
Motown
04-20-2018 09:31 AM
