The local Mini Coop has a 08 JWC Cabrario in the show room I may trade for. Here's my question: I'm driving an 07 cabby....with some extra goodies (see below). I've also tested the 09 Turbo JWC. NOT impressed. Don't like the dash....seems lazy at low end...although my test drive was in afternoon traffic so not a fair evaluation. Also a biggy for me is NO HK Sound system available in the new 09's???? What's up with THAT?
So...is there significant difference in the 08 Supercharger versus the 09 Turbo? If so maybe I'll swallow hard and go for the 09 and replace the sound system.
The turbo gives you more consistent power through the RPM range, as the turbo spools much faster then the super charger. The turbo also provides better MPG. The supercharger has the more pronounced whine, while the turbo has its characteristic 'pshh.' An 08' exhaust will have a pronounced burble, while the 09' won't.
How does the JCW compare to a "spruced up" pre-turbo? Milage is not a issue....this is my "funny" car....
I came from JustACooper, so the JCW is a huge step forward. I did drive an 05' MCSC a few times, and I do enjoy having the lower end power put out by the turbo compared to the SC. With the 05' MCSC it didn't really pull until 4500 RPM or so, where as my MCSC is in a full gallop by 3000 RPM, and keeps running well over 5500 RPM.
Love my '05 JCW vert, no problems with low end torque at all. If you want more just mod the CAI, I didn't mod mine, BUT...
There are a few easy and necessary mods to do...
1. Free flow air filter, let that baby breath!
2. An engine damper, TSW has a nice one. This is necessary to put that torque to the pavement as the engine mounts are built with jelly and the engine rocks too much. Correct installation is key to good driveability. This is a must have install for all supercharged Binis.
Looking at jumping back in a Mini myself (ex 05 MCS owner)- came across this post which has me scratching my head; how does the the turbo spool faster then a supercharger? Do you have "supercharger" and "turbo" reversed?
I'm pretty much sold on the supercharged version - mainly just for the looks...
supercharger has no need for spool up. Its driven by the crankshaft so there's zero delay. (but it imposes parasitic load to the engine)
Turbo needs to be "charged" before it unleashes its power - there is a spool up delay, no matter how well the turbine is designed.
But once its spooled up and going, turbos provide bigger boost thus more efficiency than supers.
With recent advances in light weight turbine technology, they can make turbos so light and so efficient, it has spool up delay that is virtually non detectable by ordinary drivers.
So superchargers are quickly yielding its way to turbos. In 10 years time, superchargers will become a thing of a past, like carbs.
Though the turbo lag is significantly curtailed, I did notice it in a test drive and didn't like it compared to my instant throttle response with the supercharger. Also, while peak torque comes on much lower in the revs, I personally like the more linear response on the earlier JCW's. I also don't care for the new interior. If you like your current car, I wouldn't trade . Get a cam, header and tune and you'll be more than happy with the performance! Your gas mileage will improve as well.
I'm curious.....how can a turbocharger "spool" quicker than a super charger? With a supercharger, the speed at which it turns is directly tied to the crankshaft. Any increase in crankshaft speed means the same percentage increase in supercharger speed.
With a turbocharger, the compressor is spun by the exhaust gases. In steady state running, there is also an almost direct relationship between engine rpm and turbocharger RPM. It's not a direct relationship, though, because as turbocharger speed goes up, so top does the energy required to spin the turbocharger and because the connection between the engine and the turbocharger is a gas (which is compressible) there is always some lag between engine rpm and turbo charger rpm. It eventually catches up (mostly) but the lag is always there. Manufactures have minimized this lag in recent years, but there's no way that a turbo can "spool" up quicker than a supercharger. That's part of the reason top fuel dragsters use superchargers rather than turbochargers. They want that direct, "no lag" drive to the compressor.
Ah, well, I suppose I should have looked the rest of the thread before making that last post. 'Seems it's more or less been covered. However, I would disagree that turbochargers provide bigger boost. Neither one has an advantage in that regard as it's all dependent upon the design of each. What is true, though, is that turbochargers use less of the engine's horsepower to provide the same boost.
As for superchargers going the way of the dinosaur, that may or may not happen. It's still more of a challenge for a turbocharger to make boost at low engine rpm's and then there's the more visceral sound of the supercharger that some people like. And they're a bit more simple than turbochargers. So, depending upon the market and the design requirements, superchargers may still be around for a while. Turbochargers have been greatly improved for some time now and if they were superior to superchargers in all regards, we wouldn't continue to see them. As for me, I prefer my supercharged Cab. It's got more low end grunt than the newer turbocharged versions, but most important to me is the sound. I just love it when it winds up. The turbochager sounds like a vacuum cleaner. There are many things that make a car a joy to drive. Accelleration, braking, handling, road feel, comfort, etc., etc., and one of those important things, in my book at any rate, is sound. It's part of the whole experience.
Are you talking about factory JCW's or kit JCW's?
Remember that you get the benefit of better intake valves and stronger pistons, cylinder head and gear box.
__________________ 2009 John Cooper Works Clubman: Pure Silver over Horizon Blue, Pure Silver C-Pillars, Mirrors, Hood Stripes, Cold Weather, Premium, Rear Spoiler, Front & Rear Fog Lamps, Bluetooth/USB/iPod
nm Engineering: Short Shift Adapter and Assembly Cover (06/11)
MiniDoMore: Hitch, Drawbar, Cargo Platform and Box (06/11)
pistons and gear box are no different than the stock MINI.
No,
Full press release below:
IN THE NAME OF RACING: MINI JOHN COOPER WORKS AND MINI JOHN COOPER WORKS CLUBMAN 02/24/2008 Munich. A big name, a long tradition, outstanding performance, figures and an incomparable driving experience: the MINI John Cooper Works arouses motor racing passion which goes beyond the race track. In August 2008 the new model - produced at the British MINI plant in Oxford - will be coming to Germany along with the MINI John Cooper Works Clubman. With their world premiere at the International Automobile Salon in Geneva (March 6th-16th 2008), these versions are the first two models to be launched by MINI under the brand MINI John Cooper Works. The heart beating under the bonnet of each of the two new extreme sports cars is that of a racer. The 1.6 litre 4-cylinder engine with Twin Scroll turbocharger and petrol direct injection delivers 155 kW/211 bhp (207 hp US) and develops its maximum torque of 260 Newton-metres (192 lb-ft US) between 1,850 and 5,600 rpm - by means of overboost the torque can actually be increased to 280 Nm. (207 lb-ft US). The power unit is based on the engine of the John Cooper Works CHALLENGE, which will see its premiere at the MINI CHALLENGE 2008. It accelerates the MINI John Cooper Works in 6.5 seconds from 0-100 km/h, the MINI John Cooper Works Clubman manages the spurt in just 0.3 seconds more. It is not only the engines of the MINI John Cooper Works and the MINI John Cooper Works Clubman that provide genuine racing feeling. Both models are also fitted with extensive motor racing technology as standard: exclusive light alloy rims with especially light and extremely high-performance brakes, a new exhaust system and the modified 6-speed manual transmission, also created with close reference to the new racing car for the 2008 MINI CHALLENGE. Rarely before has motor racing expertise found its way so directly onto the road. The MINI John Cooper Works will be available in Germany at a price of 27,700 Euros, the price of the MINI John Cooper Works Clubman will be 29,500 Euros. (US Pricing yet to be announced)
Fascinating power due to motor racing expertise.
The MINI John Cooper Works and MINI John Cooper Works Clubman are driven by a true power package based on the current engine of the MINI Cooper S, extensively revised for the MINI John Cooper Works CHALLENGE racing vehicle and now back on the road with refreshed power. Even the basic design of the 1,598 cc 4-cylinder engine has details which are drawn from motor racing. The cylinder block and bearing housing are made of aluminium, the four valves per cylinder are controlled by two upper camshafts, friction-optimised cam followers and hydraulic valve clearance compensation elements. The outlet valves are filled with sodium so as to meet the increased cooling needs of a turbo engine. The camshafts of the 4-cylinder are composite. Instead of using the conventional die-cast procedure, the cam rings are made of high-strength steel and shrink-fitted to the actual shaft. The intake camshaft has a continuously variable phase adjustment function by means of which the valve control times can be adapted to the relevant performance requirements.
The engines for the MINI John Cooper Works and the MINI John Cooper Works Clubman are made at the BMW Group engine plant Hams Hall (Great Britain) where the engine units for all MINI model variations are manufactured. In the case of the top-of-the-range engine, there are a number of special modifications to the production process to do justice to the increased output and the resulting higher temperatures in the combustion chamber, thereby guaranteeing maximum reliability of the drive system. The engines are fitted with reinforced and specifically ground pistons as well as a cylinder head with optimised rigidity and modified gasketing. The intake valves and valve seat rings are also made of especially resilient material, and as compared to the engine of the MINI Cooper S there is a slight reduction of the compression.
More air, more power, more torque - the formula for increased driving pleasure.
The power increase as compared to the engine of the MINI Cooper S is mainly achieved by means of optimised air intake and outlet due to an adapted turbocharger. The air filter, air mass sensor, exhaust system and catalytic converter have been modified so as to achieve a power-enhancing dethrottling on the induction and exhaust side. This is also reflected in an engine sound which is peculiar to this model. Due to the adaptation of the exhaust system,
a significant reduction of counterpressure is achieved. The MINI John Cooper Works and MINI John Cooper Works Clubman fulfil the requirements for adherence to the particularly stringent threshold levels defined by the exhaust norms EU5 in Europe and ULEV II in the US. The through-flow capacity of the clean air duct to the turbocharger has also been increased. The design of the Twin Scroll turbocharger enables an especially spontaneous power build-up. In the exhaust manifold and the turbocharger, the channels of two cylinders are separated in each case. The supercharger blades are set in optimum motion even at low engine speeds. A turbine was developed in very high-quality material especially for the MINI John Cooper Works and the MINI John Cooper Works Clubman, and the maximum boost pressure was increased from 0.9 to 1.3 bar overpressure.
The maximum torque of 260 Nm ( 192 lb-ft US) is available even at an engine speed of 1,850 rpm and up to a level of 5,600 rpm. During acceleration, torque is raised to 280 Nm (207 lb-ft US) by means of a brief increase in boost pressure between 2,000 and 5,300 rpm. This overboost function gives the MINI John Cooper Works and the MINI John Cooper Works Clubman an even more powerful response. The engine reaches its maximum output of 155 kW/211 bhp (207 hp US) at 6,000 rpm. The spontaneous response is also reflected in the car's acceleration figures. The MINI John Cooper Works takes 6.5 seconds to accelerate from 0-100 km/h, the time required by the MINI John Cooper Works Clubman is 6.8 seconds. Both have a maximum speed of 238 km/h.
Petrol direct injection: fuel is precisely measured and efficiently used.
With a specific output of 132 bhp per litre of capacity, the MINI John Cooper Works and MINI John Cooper Works Clubman advance into the realm of
the purebred sports car. What is more, both new models have the characteristic MINI quality of offering unique driving fun in combination with exemplary efficiency. The key function here is the fuel supply system. The turbo 4-cylinder is fitted with petrol direction injection according to the common rail principle. Injection valves positioned laterally in the cylinder head feed the fuel in precise doses under a pressure of 120 bar from the tank directly into the combustion chamber. This means that in every situation on the road, precise fuel supply is guaranteed which is adapted to the given load requirements. The average
fuel consumption in the EU test cycle is at an unusually low level for vehicles of this output category. The MINI John Cooper Works makes do with 6.9 litres
per 100 kilometres, the MINI John Cooper Works Clubman requires 7.0 litres. The respective CO2 figures are 165 and 167 grams per kilometre.
Conceived for maximum driving fun: chassis, brakes, assistance systems.
The standard range of features of the MINI John Cooper Works and the MINI John Cooper Works Clubman not only includes a particularly high-performance engine but also a wide range of other components which ensure that this irrepressible power is put safely onto the road. As is characteristic
of MINI, the engine powers the front wheels. The MINI John Cooper Works and MINI John Cooper Works Clubman are fitted with a 6-speed manual transmission whose components have been adapted to the very high level of torque of this new top-level engine. In addition to the sophisticated chassis technology with McPherson struts at the front axle and the central control arm
rear axle, which is itself unique in the small car segment, the electromechanical EPAS (Electrical Power Assisted Steering) is a further guarantee of reliable
and precise handling. The electrical servomotor also contributes to efficiency in that it is only activated when steering support is required or desired by
the driver.
The steering system EPAS allows various settings to be programmed. The basic set-up guarantees balanced steering support depending on road speed. With the sports button, which is positioned as standard next to the gearshift lever in the centre console in the MINI John Cooper Works and MINI John Cooper Works Clubman, it is possible to activate a perceptibly more dynamic characteristic curve with higher steering torque and increased steering precision. In keeping with this, pressing the sports button also changes the accelerator pedal to a much sportier characteristic setting.
The MINI John Cooper Works and MINI John Cooper Works Clubman are fitted with sporty suspension settings as standard. As an alternative, a sports chassis with harder damper characteristics and stronger stabilisers is available for the front and rear axle. For a more extreme racing orientation, there is also a John Cooper Works chassis available in the accessory range for the MINI John Cooper Works. It includes a lowering of the suspension by 10 millimetres, even harder damper characteristics and stabilisers with a diameter which is larger than those of the sports chassis.
The standard sports brake system guarantees short braking distances and is characterised by precise response and fine controllability. The fixed calliper
disc brakes with aluminium callipers finished in red - inner vented on the front wheels and bearing the John Cooper Works emblem on the callipers - are large in their dimensions. The type and function of the brake system is based on those in the MINI CHALLENGE racing vehicle. The same applies to the exclusive 17-inch light alloy wheels in John Cooper Works Cross Spoke CHALLENGE design. Weighing less than 10 kilos, they are the lightest standard wheels within the competitive environment of the MINI John Cooper Works and MINI John Cooper Works Clubman. The high-speed tyres in 205/45 W 17 format have runflat properties, and both models are equipped with a tyre damage display function.
As standard and unique in front-wheel-drive vehicles: DSC with DTC.
In addition to sporty suspension settings and powerful brakes, the MINI John Cooper Works and MINI John Cooper Works Clubman also have sophisticated driving stability systems. Their standard equipment includes ABS, EBD (Electronic Brakeforce Distribution), CBC (Cornering Brake Control)
and DSC (Dynamic Stability Control) including hill-start assistance and DTC (Dynamic Traction Control). By applying the brakes to individual wheels and reducing engine power, DSC applies a stabilising effect when required, intervening early on to prevent the vehicle from swerving at the front or
rear wheels in especially dynamic driving situations or on slippery surfaces. The brake assistance function, likewise an element of DSC, detects
emergency braking situations and ensures instant build-up of maximum brake pressure should the need arise.
DTC is a sub-function of DSC which is available here for the first time in a vehicle with front wheel drive. It enables the response threshold levels
of driving stability regulation to be increased so as to allow controllable slip on the drive wheels. In this way, the models MINI John Cooper Works
and MINI John Cooper Works Clubman can be controlled on snow-covered surfaces or loose sand with slightly spinning front wheels, or taken more intensively to the physical limits in highly dynamic driving situations. When
the threshold range is reached, the stabilising intervention of DSC is also guaranteed in DTC mode. If necessary, DSC can be entirely deactivated.
What is more, in DSC-Off mode an electronically controlled lock function for the differential of the drive axle is activated. This system is also a standard feature and known as Electronic Differential Lock Control: it supports an ambitious, sporty driving style when accelerating out of bends and hairpins, for example. The electronically controlled lock function has the effect of applying specific, appropriate brake force to a spinning drive wheel on tight bends.
This enhances the forward propulsion of the vehicle without having a negative impact on self-steering response. The bend can thus be taken more smoothly but also more swiftly.
Interior:
sports car ambience and a wide range of individualisation options.
In the interior, the standard fittings of the MINI John Cooper Works and the MINI John Cooper Works Clubman boast a strikingly impressive elegance which is both simple and sporty in style. A three-spoke steering wheel in leather is the point of connection between the driver and his sports machine, while the anthracite roof liner and the interior surfaces in a glossy Piano Black finish create a calm atmosphere which promotes concentration on the road. Another feature of the two top-of-the-range sports cars is a speedometer scale which goes up to 260 km/h.
In addition, MINI also offers a wide range of individualisation options for configuring the two new extreme sports cars. In terms of exterior paint finishes, interior design, seat upholstery types, interior colours and decor options
as well as the comfort features, the full breadth of variety is available as for the other model variations. Additional comfort, versatility and sporty flair can be achieved with items from the extensive accessory range of MINI and of
John Cooper Works.
Ten exterior paint finishes are available to choose from for the MINI John Cooper Works and the MINI John Cooper Works Clubman. Contrasting roof finishes and roof decor options provide a wide range of possible combinations. The basic fittings of the interior include seat covers in the fabric Chequered. Optional extras include leather upholsteries, sports seats with fabric/leather covers, sports leather seats and Recaro sports seats from the John Cooper Works accessory program. The decor strips of the interior can be selected in Fluid Silver as an alternative to Piano Black. The accessory program also includes an interior strip in Carbon.
The high-quality entertainment and navigation systems of the MINI equipment range are also available for the two top-of-the-range sports cars. The
controls of the audio system - with CD player as standard - and the 6 ½ inch TFT colour display of the optional navigation system are situated in the central circular instrument. The standard AUX socket enables music saved on
an MP3 player to be played through the audio system, for example. A special interface for full integration of an Apple iPod is also available as an accessory. For optimum and safe communication on the road there is an optional mobile phone preparation or integrated hands-free facility with Bluetooth interface
and USB connection. An interface for integrated operation of the audio and telephone functions is also specially available for the Apple iPhone.
Performance at premium level: John Cooper Works accessories.
The highlights of the John Cooper Works accessory program include the aerodynamics package and sports chassis with springs finished in red for the MINI John Cooper Works, as well as perforated brake discs and rear spoilers
for both model versions. Other items include a suspension cross-brace for the engine compartment, mirror caps in carbon finish and so-called side scuttles - direction indicator surrounds with a sporty grid structure. To match this there are also decor strips, handbrake handles and sports gearshift levers in carbon decor which provide an even sportier ambience. The gear shift indicator in the John Cooper Works accessory program also contributes to an intensive driving experience.
With the John Cooper Works Performance components, the character of the two new models is given even greater emphasis and visually highlighted, too. Premium-quality sporty flair characterises them as it does the two
new models themselves, both of which bear the John Cooper Works logo.
have to be able to meet both the extreme challenges of the race track as well as the extensive requirements of everyday traffic in terms of functionality, design, reliability and durability. Together, the brands MINI and John Cooper Works stand for a promise of quality which is uniquely powerful within the competitive environment of MINI.
MINI and John Cooper Works: shared roots in motor racing.The two top sports cars are sold through the MINI dealer network. Like all variations of the MINI and MINI Clubman, both models are manufactured at the MINI plant in Oxford according to customer wishes. In this way, the integration of the John Cooper Works label under the umbrella MINI is now also reflected in the range of vehicles available ex works.
The close connection between MINI and John Cooper Works, based on a motor racing tradition stretching back decades, has a defining influence on the development of new vehicles and components. The MINI John Cooper Works and MINI John Cooper Works Clubman represent the shared values of driving fun, premium quality and individuality in an especially concentrated form. In terms of reliability, quality of workmanship and authenticity of design, they fulfil the high standards of the BMW Group, as do the John Cooper Works Performance components with their perfect adaptation to MINI. The new models are thus also subject to the warranty conditions applicable to MINI.
It is true that a super does not spool up but the torque curve of the MINI turbo is very flat (almost full torque at 1400 RPM) and there is more torque available at low engine speed with the turbo vs the super. It is the reverse of what has always been expected but the MINI turbo is amazingly quick to spool up. You can hear the turbo whistle just off idle speed.
__________________ '09 MCS Convertible - Dark Silver with Tuscan Beige Leather/Piano Black/6 Speed Manual/Convenience/Sport/Cold/Premium/Mini HiFi/Black Bonnet Stripes/Armrest/17" Web Spoke Wheels/Michelin Pilot A/S Plus tires/Backup Camera /JCW Carbon Fiber Hood Scoop/Multivex Mirrors/Cocomats.com mats/2010 HK Speakers/Sound Deadening/Anti-torque steer reprogram 4/25/09 (Ordered), 5/08/09 (Built), 5/30/09 (at dealer), 6/3/09 Drove Home!
I don't know if the Supercharger vs. Turbocharger issue will ever be settled
but I wish that MINI would have left that choice up to the consumer.
They should offer an option to go with either type engine package.
As it stands I will never trade my SC for a TC, I am addicted to the whine.
Ditto. I love the whine on mine as well. I took my sister-in-law for a quick drive in my JCW yesterday and besides generally being amazed ("That's the FASTEST I've ever taken that off ramp!), she really loved the supercharger whine. Though that's to be expected, I suppose, as she's a gear head and races motorcycles.
Turbo chargers come in various sizes, and if you match up the turbo size to engine displacement, and you'll see how a turbo can out-spool a SC.
FYI, the R56 turbo gets full boost by 3000rpm due to it's relatively small size. But the downside of this is the loss at top-end. At 5500rpm, that littel turbo runs out of breath.
there is a writeup on Mini Torque if anyone cares to take a look at the graphs over there.
Gotta have heard the whinning with the top down to know what we're talking about I guess..
Supercharger Whinning Rules!
Allow me to be the first to welcome you to the MINI world.
I of course agree with your assesment that the supercharger whine is best enjoyed with the top down.
