MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > R52 :: Cabrio Talk (2005-2008)
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Advertisement
Thread Tools Search this Thread
Old 06-27-2009, 02:09 PM
BCMini's Avatar
BCMini BCMini is offline
Gallery
Convt top not workg after battery change.
I've read all the "Top won't work" posts I could find and already tried the "napkin over sensor", "latch unhooked", "shelf button not depressed" fixes, but none helped. Oddly, after getting a new battery installed today by a local mechanic (non-dealer, as they are 120 miles away) there appears to be no power to the top control buttons. Depressing the up or down button results in no movement and no red light. However, the window control buttons work fine, as do the main window switches. So, no top down, no sunroof, no fun! :-(
Maybe there's a control module that has to be reset after a battery change? I found these instructions in the owners manual for the windows, radio, & Nav, but no mention of how to re-initialize the top control buttons. HELP!!!! I'm in FL and can't go topless.
05 MCSC
Old 06-27-2009, 02:12 PM
CR&PW&JB CR&PW&JB is offline
Gallery
Cycle the windows up and back down.
Roof will work.
http://www.mini2.com/galleries/data/500/CR_PW007.jpg
Old 06-27-2009, 02:54 PM
BCMini's Avatar
Gallery
Windows cycle up and down fine, but no effect on top's operation (no red light, no movement of top occurs when retract button is depressed). I tried using key's convenience approach and it works to put windows down and then upon second click of key you hear the expected sounds of the mechanism 'clicking' just before the top motor usually starts unlocking the top and then retracting it, but no unlocking occurs and no motor sounds from the top. I also used the key to put up the windows via the lock. Turned the car on and off in between cycling windows, using convenience approach, etc... still no movement from convt top. I know the top works fine, as I had just put up the top when I arrived at the mechanic's place before they installed the new battery.
Old 06-27-2009, 05:31 PM
Gallery
Yeah, there's no problem with your roof, it's the electrical system playing games with you. Happened to me at MOTD when they unplugged my battery to install the pulley. For me, cycling the windows once did the trick.
Since that didn't work for you, also make sure your parcel shelf in the boot is in it's proper position. Unlock and re-lock the levers in the boot, too.
Of that doesn't do it, sorry... I'm out of ideas.
Old 06-27-2009, 06:04 PM
BCMini's Avatar
Gallery
Yep, that's what I figured too - electrical gremlin. I tried the shelf, latches, etc... to no avail. Thanks for the window cycling idea, it was definitely worth a try and interesting to hear it worked for you. Cheers.
Anyone else have any experience or ideas on this issue?
Old 06-27-2009, 08:09 PM
rkw rkw is online now
Gallery
At this point, I guess it wouldn't hurt to try resetting it again. Disconnect the battery and let it sit for a while, like 30 minutes, then reconnect.
I have a cabrio and disconnected the battery numerous times while installing mods, and never had a problem with the top. Never needed to cycle the windows.
Old 06-28-2009, 07:29 AM
BlimeyCabrio BlimeyCabrio is offline
Gallery
Checked all your relays and fuses? The relays rattle loose sometimes...
Check all the relays in the under-bonnet fusebox. The convertible top fuse is FL3 - which I *think* is actually underneath - if so, you have to remove the fuse box to access it.
I'm Paul, The car is Blimey--- BlimeyCabrio's Blog--- 2006 MCSCa w/lotsa mods and Union Jacks
Ten-time Dragon Veteran - Occasional Trackrat - Extreme Twisty Addict - Rhymers Ferry Road Fanatic
Old 06-28-2009, 10:47 AM
Gallery
Good thought -- seems obvious but I didn't even think of the fuses. The fuse for the roof control module is F01 in the engine compartment and the roof motor is indeed FL3 (F01 on top, FL3 on bottom of fuse box). Also check F15 in the footwell fuses. The relays I see in the wiring diagram are all in the roof motor area in back.
Old 07-02-2009, 04:43 AM
BCMini's Avatar
Gallery
Thanks! I checked the fuses on top and all looked good. I'll check the footwell and bottom ones this evening.
Old 07-04-2009, 09:36 PM
bullyx2 bullyx2 is offline
Gallery
Hello. Did you ever come up with a resolution on this? I have a friend's mini at the house. Similar situation in that I had the battery disconnected for a day, with the top down, to install an audio system. Long story short, i am having the same issue. I actually had power to the top enough to raise it back into place, but almost like the "sunroof" motor wouldn't take over. Latched wouldn't latch and sunroof portion wouldn'r close. I closed it manually and now have the exact same thing as you.
Old 10-08-2009, 01:11 PM
BoneHead BoneHead is offline
Gallery
I just changed out the battery on my 2005 MINI convertible and had the same issue of top not working. In my case it was already down and each hit of the button got a 1 second burst of the motor. Subsequent hits got the top all the way up but it would not latch. I reversed the process and after multiple button hits got the top back down again. Good news is cycling the windows up and then down again (with the car running the whole time) fixed the problem and the top now works fine..... It be gremlins for sure! Thanks for the tip!
Old 10-13-2009, 07:24 PM
baxman01 baxman01 is offline
Gallery
I had a similar situation. Had a non dealer replace the latch bracket on the top. Once they finished the top would not go down, sun roof opened, press button the second time to lower the top, windows drop down a few inches, latches open and nothing. After several days of trying they took it to a dealer in Atlanta. Dealer reprogramed the software and said I needed a new cassette, (the entire top section $2600) I told them to go bite themselves top worked fine before the latch repair. When I got it back from the dealer the top worked fine. Called and asked they said I need a cassette. Now I just cross my fingers when I press the down button.
Smitty
Old 10-16-2009, 01:06 PM
martinb martinb is offline
Gallery
Many of the newer cars out there have all kinds of fancy electronics controlling just about everything on the car. When you change out batteries nowadays, it's highly, highly recommended that you hook up a temporary battery just to keep the electronic memories running and functioning while the main battery is replaced. If there's an access port like a cigarette socket that's always on regardless of the ignition switch position, then a small battery can be hooked up that way. Otherwise, you need to clip or temporarily attach leads to the battery cables before you remove them from the battery. I have a motorcycle battery that I use for this and it works perfectly. Just attach the leads to the cables and then take your time replacing the battery. Just don't try to start the car or run any accessories with only the smaller battery in place.
Old 09-24-2011, 08:07 AM
narsisco lopez narsisco lopez is offline
Gallery
I know this is an older thread, but does anyone have any further insight to this issue?
I just bought a 2005 Cabrio S (65K miles). The previous owner advised me that the battery was going dead (he stupidly-left interior lights on all night in his garage, or so he says) and gave me a bit of credit for a new one.
The first thing I did was take the car to the local Sears for a new battery. After the tech was done, I happily drove off. When I pull into the parking lot of the local DMV to get my plates, I tried to close the roof... no light, no motor noise, no nothing.
Being very forum savvy, the first thing I did was to do a Google search and found this thread. So, I tried the window cycling trick... nothing. I think the parcel deck is secure, but for the life of me, I can't find the interlock switch you guys keep referring to. Anyone have any photos of where it is? I think the deck is correctly in position, but can't be sure.
While waiting, I've disconnected the battery and am waiting the suggested 30 minutes.
Any help or additional information is greatly appreciated!
DISREGARD: While waiting the 30 minutes after disconnecting the battery, I decided to check the fuses (F3 an F15)... F3 was blown. Replacing it with the spare fixed the problem!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
