MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > R50/R53 :: Hatch Talk (2002-2006)
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post R53 issues
12 Replies, 514 Views
Advertisement
Thread Tools Search this Thread
Old 04-09-2007, 09:15 AM
goaljnky's Avatar
goaljnky goaljnky is offline
Gallery
Oxygen Sensor Replacement?
I am reading a catalog from Atlantic British/MiniCarparts.net. One of the items is the Catalytic converter oxygen sensor. The description claims that the oxygen sensor should be replaced regularly.
Is this true? And if so, what would be considered regularly?
Old 04-09-2007, 09:48 AM
Partsman Partsman is offline
Legion_of_Doom
Gallery
Did they happen to specify front or rear? or both?
Unless you had SES light that required it's premature replacement, and depending on your vehicle's state of tune(rich/lean), I would think that 60-75k would be a pretty good interval on the factory sensor.
Old 04-09-2007, 09:52 AM
goaljnky's Avatar
Gallery
They are saying front and rear. Here is the link to the web page:
http://www.minicarparts.net/Parts/M3095.cfm
Old 04-09-2007, 09:57 AM
Eric_Rowland's Avatar
Eric_Rowland Eric_Rowland is offline
Gallery
I've seen 50K tossed about, but don't know how much of that is marketing by Bosch vs. vehicular requirements...
'04 IB/W MCS w/all the goodies, Ian's auto-up/GDO, MMC#I69/MID CURV169; power folding mirrors
"You can't save the world unless you're willing to make other people sacrifice." - Dogbert, via Pendergast
Old 04-09-2007, 10:02 AM
olngry olngry is offline
Gallery
BMW says 100k on other models.
Old 04-09-2007, 10:05 AM
Legion_of_Doom
Gallery
Most people don't even think about replacing the O2 sensor until it goes bad. Considering they live in a rather harsh enviroment, regular replacement does make sense.
I wouldn't recommend using anything other than a genuine BMW/MINI part.
Old 04-10-2007, 02:00 AM
mylittlemini mylittlemini is offline
Gallery
unless your getting an SES light or noticing some drivablity problems it really isnt worth the cost of replacing the sensors. the ecu is able to adjust to the degradiation of the sensor and once the sensor is getting worse youll start to notice difference in engine operation and possible getting lean or rich codes before youll get an o2 operation code. it is also sometimes recommended that if you replace the upper sensor you should also replace the lower sensor at the same time. has something to due with the learning curve of the ecu. i wouldnt change the sensors unless it is necessary. the warrenty for the sensors is 100k i believe.
sorry for the mildly long post
Old 04-10-2007, 10:17 AM
goaljnky's Avatar
Gallery
Thanks for the info everyone. I will now return to my worry free motoring.
Old 04-16-2007, 07:30 AM
thatatvguy's Avatar
thatatvguy thatatvguy is offline
Gallery
Has anyone cross-ref'd this part number from the OEM?? From the dealer it's about an arm plus half a leg. It should be a "normal" O2 sensor, correct?
Sydnee - '06 MCS HB/B
Got Mods? - www.ddmworks.com www.waymotorworks.com
Old 04-16-2007, 07:06 PM
NMgokart NMgokart is offline
Gallery
MINI uses a 4 wire, heated sensor. More expensive than most. Cheapest I've seen it is $189. Each.
MINIless for the immediate future. :(
Previously owned:
06 Justa Cooper Astro Black
03 MCS BRG and lotsa mods
06 MCSA HB and even more mods
Old 04-16-2007, 07:18 PM
89AKurt's Avatar
89AKurt 89AKurt is offline
Gallery
Quote:
*gag*
My "check engine" light has intermittantly been on. I called the MINI service dude and he said the change of winter to summer fuel is messing up O2 sensors. Sometimes I have had rough idling. Is this something someone mechanically challenged (me) can change out?
Visit Arizona... speed for the cameras and reduce our budget deficit!
2007 MCS JCW Dark Silver/Black DSOC89 Traded Swifty 10/20/11 My Flickr
Old 04-17-2007, 10:27 AM
Gallery
If you've got a 22mm wrench and some patience, it shouldn't be a problem. I haven't done a MINI, but have on several other cars.
Old 04-17-2007, 11:44 PM
Gallery
yep its not to difficult. just dont bust your knuckles when the sensor decides to break loose. also its a good idea to put some anti-sieze on the threads but make sure you dont get any on the probe thats in the exhaust flow. torque spec is 28 ft. lbs or as tight as you can get it.
Old 06-30-2007, 12:55 PM
roadodendron roadodendron is offline
Gallery
Replacement Oxygen sensor
Replaced my pre-cat sensor with a universal 4-wire. No problem with removing and replacing the sensor. It came with a nice splice in kit to attach to the original connector.
The details: Bosch 15729. O'Reilly had it listed for a 1997 AMC-JEEP grand Cherokee. The irony of that! My out-the-door price was $63.59.
Mine: Rita - 04 BRG/W MCS premium, sport, anthracite
Hers: - 08 PW/B MCa premium, sport susp., Xenon, Cream White, English Oak
Old 07-07-2008, 08:12 PM
windman windman is offline
Gallery
Has anyone else tried what goaljnky did? I think I need to replace my o2 sensor but really dont want to pay that much. I would rather spend the money on cold air injection.
Old 07-26-2008, 08:00 PM
jrprich jrprich is offline
Gallery
Rockauto.com
ACDELCO Part # 2132908 {#19107252}
SENSOR,HTD OXY(POSN 1) IN EXH MANIFOLD/CROSSOVER-4 WIRE
SENSOR,HTD OXY(POSN 3) POST CONVERTER-4 WIRE$96.790.00$96.79
None at present
wife's MINI's CVT went bad and we wholesaled it ;^(
My DD is a 99 Vette ;^)
Old 07-26-2008, 08:40 PM
jimz68 jimz68 is offline
Gallery
149K miles on the original sensors. I'm waiting for the hammer to fall.
Jim
2004 MCS with (More) Stuff
www.flickr.com/photos/jimz68/sets/
Old 07-26-2008, 09:25 PM
hemiheaded18 hemiheaded18 is offline
Gallery
Unless that is a universal, I don't know where that PN came from as this is the one I've always seen:
http://www.partsamerica.com/productd...pe=291&PTSet=A
And FYI, $125-150 is average for the most part. Some get up into the $250+ range with an OE Honda wideband 5 wire the most I've ever seen at like 400 I think.
Old 07-27-2008, 07:09 AM
lvbltec's Avatar
lvbltec lvbltec is offline
Gallery
just put one from MINI in when it finally fails. that way you know it should be good for x amount of time. and the rest of your mods are still based on a factory reading to the dme from the o2.
Old 07-27-2008, 10:52 AM
Ancient Mariner's Avatar
Ancient Mariner Ancient Mariner is offline
Gallery
More often than not, the O2 sensor works fine (with a little help from the ECU) then fails completely. If the SES light isn't on and you don't have a code for O2 sensor failure, don't worry too much about it. Replacement can be a minor PITA, but it's not an emergency when it does fail. Power is degraded somewhat, mileage goes in the toilet (wait, at these fuel prices, maybe that is an emergency). The car goes into "Limp-home mode", but is driveable.
[IMG]<a href=http://www.northamericanmotoring.com/gallery/data/500/medium/fullSig.JPG target=_blank>http://www.northamericanmotoring.com...um/fullSig.JPG</a>[IMG]
Lasciate ogne miseri, voi ch'intrate.
47°13'29.45"N - 122°10'28.83W
Bone stock (sort of) 02 of 02 MC
Old 07-28-2008, 07:22 AM
Gallery
Over time they slowly lose metering ability and that comes with power off a little and slightly less gas mileage but then they usually give up the ghost fairly quickly after that. Once they go, the car just runs massively rich. It's nothing bad, just kinda runs like crap and mileage drops off quick.
Old 07-28-2008, 02:53 PM
Davidf Davidf is offline
Gallery
Like others have said, the DME (engine computer) will compensate for normal aging of the pre-cat sensor. once the sensor falls out of range, the SES light will be illuminiated and a code stored.
The post-cat sensor does nothing other than monitor the health of the cat itself. So, absolutely no benefit in replacing the post-cat (rear) sensor unless it fails. The post-cat sensor is sort of like a qaulity control device. last check before things go out...
Old 07-28-2008, 04:41 PM
Gallery
^^^Yep, before cat monitors A/F ratio and determines mixture, after cat measures cat efficiency.
Old 11-25-2008, 05:53 AM
Roadsailer's Avatar
Roadsailer Roadsailer is offline
Gallery
http://farm4.static.flickr.com/3124/2593498291_901fd58e41_o.jpg
Old 11-25-2008, 07:36 AM
newbs49 newbs49 is offline
Gallery
Are we sure about the #'s. We have two different #'s for the Bosch. The o's are the same.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
