R50/53 squeaky noise from engine
serpentine belt replaced 2 weeks ago. Have is nasty sound now. Any suggestions on what it could be? Or what would cause this or how to fix.
https://youtu.be/6Sgz0xs2AUA
thank you
thank you
Sounds like the belt tensioner or another pulley.
Pull passenger wheel and the passenger wheel shroud. Get a couple empty paper towel tubes, tape together and put one end to your ear and the other towards the suspected areas. This will narrow down where the noise is coming from. Yeah I know its not easy to get to each area, but you asked.
You can probably get away using one but I use two to help my hands away from moving parts.
Otherwise I have seen folks try WD-40 one pulley at a time.
Good Luck
Bruce
Good Luck
Bruce
took the wheel well apart, listened closer to where the noise was coming from. Sprayed the pulley WD 40. noise started to disappear after 1 little spray. sprayed more until it was gone. Thank you. heres a video. The pulley will need to be replaced sooner than later, correct? Anyways Thanks a bunch!
https://youtu.be/G8MXunAxFB8
