Oh no! R53 window won't go up!
So today on my way to work I put the window about half way down. When I stopped at the gas station I went to put it up but it only went up a few inches, it's almost like it's jammed... Or the motor doesn't seem to have enough power to push it up?
I tried the 3 punch above the speaker method and nothing. The window will roll down, but once it gets to the same point it just stops.
Anyone experience this? Thoughts? Shot motor?
Thanks guys!
Thanks guys!
Yea... Rain tomorrow, so I'm a bit depressed, I won't be able to drive it tomorrow.
But on the inside, the cable towards the front doesn't seem to give enough slack for the window to go all the way up. It's like the CPU thinks the window is up... The cables seem to work fine otherwise.
Basically, is there a way to reprogram the window settings?
It's the same part. The cables you see are part of the regulator assembly. I got one awhile ago when my driver side window started messing up, but gave up on trying to replace it myself. Trying you maneuver your hands and tools in that tiny little space in the door is a good way to make you scream. I ended up realizing the door bang trick worked for me and the window still works a year later, though it drags a bit on the way up.
I think when you install a new motor/regulator, you need to initialize the system. I think the process has you roll the window all the way up and hold it up, then all the way down, then back up. Something like that. Of course that won't work if your regulator is preventing you from rolling it all the way down/up.
Also, the door bang trick works! Lol. My R50s passenger door did it, still works to this day.
On my R53 though it seems like too much cable is stuck in the motor or regulator, not allowing it to roll all the way up. That's why I was wondering if there was anyway to reset this?
If you have to replace your regulator, this article works to a tee.
http://www.pelicanparts.com/techarti...eplacement.htm
During my searching I can't across alot, and I mean a LOT of post about people complaining about squeaking windows. Seems like it's a precursor to a bad window regulator or motor.
Has anyone figured any preventative maintenance to remedy this?
R50/53 Putting car on jack stands
Photodesign
12
09-25-2016 08:03 PM
