R50/53 Bad lifters or ?
There are no lifters, rocker arm rollers ride right on the cam shaft.
It's hard to tell from recorded sound, but usual culprit is bad timing chain tensioner piston, does the sound subside with RPM? This adds tension to the chain and would normally take out the slack and lessen the noise.
If it is the tensioner piston, it's a common problem and an easy fix.
I tried to do this procedure http://www.enginebuildermag.com/2009...ppet-problems/ and the EML light came on. It pretty much died after that.
Jeff, sorry about your luck, as Blwnaway said; you'll likely be pulling the head to find either burnt exhaust valves or piston/ring damage (a little less likely).
What ever the outcome is keep us informed, we'll be glad to help you along the way.
If you end up needing a head we have a rebuild out at the machine shop right now getting decked, cleaned, new valve guide seals. Give us a call if you end up in the market.
586-792-6464
586-792-6464
I did a leak down test, but don't think I did it right. I did a compression check afterwards and #4 cylinder had 150psi it had 90psi last week. I'm still getting a #4 cylinder misfire code also. This car sure is screwy. I suspect the flywheel is screwed up since 2 different engines have the same noises. Question how do you tell the flywheel is bad.
Facebook Post
rondelli
07-16-2016 04:33 PM
lukgar1
04-25-2016 01:19 PM
03-24-2016 11:31 AM
