R50/53 Changing to duel gage pod 2004 r53
Old 07-30-2016, 10:56 AM
SethC's Avatar
SethC
SethC is offline
Hey everyone I'm trying to figure out if it's possible to change from my single steering wheel gage of my r53 to a duel gage cabrio of the same year. Thanks!
Old 07-30-2016, 12:54 PM
rkw's Avatar
rkw
rkw is offline
The cabrio began with 2005 model year, so there are none with the same year as yours.
If you want to swap only the tach to a dual gauge, it has been attempted before but never successfully. It is possible (has been done before) to swap in the entire Nav system along with dual gauge and harnesses from a donor car.
Old 07-30-2016, 01:05 PM
SethC's Avatar
SethC
SethC is offline
Bump
Old 07-30-2016, 01:11 PM
RB-MINI's Avatar
RB-MINI
RB-MINI is offline
Yep, things don't seem to work 100% if not done with a new NAV or Chronopack center cluster. The center cluster controls the gauges on top of the steering column. At the minimum, the dummy lights and warnings are incorrect because they are in a different position on the steering column gauge. You might be able to correct this with custom gauge faces, but the 2 gauge retrofit isn't as easy as it seems.
Old 07-30-2016, 02:13 PM
rkw's Avatar
rkw
rkw is offline
Bump
Seriously? Two hours after you posted the question?
InnocentiMini
10-12-2018 06:10 AM
2001f4s
04-29-2016 05:42 AM
MothAudio
04-03-2016 06:34 PM
GBMINI
05-30-2002 11:41 AM
Quick Reply: R50/53 Changing to duel gage pod 2004 r53
