R50/53 06 cooper S
06 cooper S
I changed the fuel filter on my 06 Mini Cooper S and I replaced the O rings and gasket along with the filter itself. Now it won't start even after I primed it several times. I know I put the gasket on right and I know there is no air leaks from there. I remove the fuel line from the filter housing and my pump pumps the fuel out fine so I know the fuel pump is not the problem. My line is just not wanting to get pressurized. I have a full take of gas as well. Any ideas?
Sounds like you either omitted the sealing o-rings inside the filter housing or they didn't seat properly. You'll need to take it apart and make sure the o-rings are where they need to be.
moremini
04-20-2016 07:08 AM
JWA
03-20-2016 04:29 PM
R50/53 Mini Cooper vs Golf GTI
miniminimini
07-11-2002 09:49 PM
