R50/53 2003 s help
Old 07-18-2016, 09:12 AM
lillduff's Avatar
lillduff
lillduff is offline
2003 s help
hi heres a list of mods and it runs very very rough at low rpm and runs well high rpm
head port polish big valves schrick cam
intake port polish
17% pulley
ati super harmonic bottom pulley
intercooler form mitsubishi evo 12 front mount
jcw 380 injectors
2.5 od exhaust
msd coil
msd wire set new plugs
shark tuner
thats it i think hope you can help thanks
Old 07-18-2016, 10:57 AM
IQRaceworks's Avatar
IQRaceworks
IQRaceworks is offline
intake port polish
17% pulley
jcw 380 injectors
2.5 od exhaust
msd coil
shark tuner
You might want to give some more info and detail.......
Did it start running rough all of a sudden, after a certain mod, or has it always ran rough?
Have you checked your spark plugs and wires? Have you checked compression? Have you checked the engine vacuum at idle? Have you done any other trouble shooting?
If the motor is mechanically in good shape, I would take a look at that Shark tuner.
Also....can you post up some pictures of your EVO12 Front intercooler mod? I'm interested to see how you did the plumbing from the supercharger to the intercooler, and the back to the cylinder head.
Old 07-18-2016, 12:53 PM
lillduff's Avatar
lillduff
lillduff is offline
hi thanks for reply car running fine till i had it e tested it did overheat aswell after e test will post some pictures as soon as i can
Old 07-18-2016, 01:33 PM
David.R53's Avatar
David.R53
David.R53 is offline
How does a smog test work where you are? Here they just hook it up to an OBDII reader and check for codes and ready status.
Old 07-18-2016, 02:09 PM
lillduff's Avatar
lillduff
lillduff is offline
hi same here in ontario Canada car was runnig fine till e test when it came out of shop it was idling very badly missing hesitating at low rpm but when put your foot hard in to it goes like a rocket thanks
Old 07-18-2016, 02:34 PM
David.R53's Avatar
David.R53
I'm guessing it's just a coincidence then and not something the test did. I would start with carefully going over the intake connections and vacuum hoses to make sure nothing popped off or broke.
Old 07-20-2016, 10:55 AM
IQRaceworks
You mentioned that it overheated during the e test? How did that happen? What do they do when they put the car through the test? Wide Open Throttle for long periods of time?
Just trying to get some more details......trying to figured out how an emissions test would overheat the motor.
Old 07-20-2016, 07:11 PM
lillduff's Avatar
lillduff
lillduff is offline
hi fan stop working over heated on the way home from test they just do obe test ,do you think i need more fuel or maybe less i have 380 injectors thanks
Old 07-21-2016, 05:37 AM
IQRaceworks
It sounds like you have multiple questions all wrapped up into one. If the car was running fine before it overheated.....then your problem is most likely a result of the motor overheating. How hot did the motor get? Did it blow a head gasket? Have you check compression?
As far as the tuning question you had....more or less fuel with the 380 injectors, I would get your car running right before ever playing with the tuning. Do you have an A/F gauge? Without that, you are going to have a hard time tuning the car on your own. Who tuned it for you the first time? Are you doing the tuning yourself via the shark tuner??
How long have you had the car? Did it have all the mods when you got it? If not, did you do all the mods?
Im a little lost here......
Old 07-21-2016, 07:35 PM
X757XVeritas's Avatar
X757XVeritas
X757XVeritas is offline
I see you say fan stopped working. Sounds like electric issues, maybe a blown low speed relay?
jstines
R60/R61 Stock Problems/Issues
20
04-19-2022 07:53 AM
Rich.Wolfson
16
01-28-2020 02:58 AM
wizardbill
27
03-29-2005 09:41 PM
kneedrachen
11-03-2002 06:48 AM
billyg
09-22-2002 04:36 PM
Quick Reply: R50/53 2003 s help
