R50/53 Best place to buy parts??
Have been checking some of the websites, and the one I want to use, seems to be charging quite a bit.
$140 for shipping?!?!?! you kidding me? Its a bunch of gaskets/hardware/water pump/etc. Nothing big or super heavy.
Any places do a discount for military? I hate being a cheap ***, but spending $1400 and then another $140 for shipping is crazy to me.
Here is what I need
Bentley Manual
Timing tool kit
Valeo Flywheel/clutch and guide tube
Powerflex CAB
Complete Engine Gasket Kit (oil pan, headgasket, S/C gaskets, crankshaft, front, rear, valve cover gasket, intake manifold, exhaust manifold, etc)
Dipstick o-ring
Exhaust manifold bolts
Exhaust manifold flange gasket
Head bolt set
Oil Filter (x2)
Drive belt
Oil filter housing gasket
OEM water pump
Thermostat housing w/thermo and o-ring
water pump hose
3-way coolant pipe
4-way coolant pipe
Any help would be appreciated. Otherwise, I'll start price checking the other places.
Here is what I need
Bentley Manual
Timing tool kit
Powerflex CAB
Dipstick o-ring
Head bolt set
Oil Filter (x2)
Drive belt
OEM water pump
water pump hose
3-way coolant pipe
4-way coolant pipe
I too am new to Mini and am looking for reasonable part prices. From what I've seen so far Parts Geek has good prices but is one that charges a lot for shipping. From an order I was ready to place they wanted to charge me for shipping for each shipment that was coming from each warehouse. My cart had stuff from three different warehouses so they wanted to charge me for 3 shipments. I didn't end up placing an order yet so I don't know if they would correct that end in the end. Do they?
Last edited by RudeJoe; 05-22-2016 at 08:13 AM. Reason: Changes supplier name - I realized I listed wrong supplier
http://www.waymotorworks.com/
They will charge you the correct shipping charges.
I've used them for a bunch of stuff, competitive prices and fast shipping.
Rock Auto usually has the cheapest prices but the parts often come from different warehouses. Best place to to get non oem parts. Oem a lot of times is better so choose wisely for some of the parts. They also have the cheapest price on the valeo clutch kit at $361 . If you use rock auto make sure you get the 5% off discount.
Never hurts to check Amazon too
http://fcpeuro.com
Reasonable and quick shipping. Lifetime warranty on ALL parts. Even wear items i.e. Oil filters, brakes etc
Nik
Nik
I feel like you might be talking about way motor works with the shipping thing. If you are then don't worry he adjusts the shipping and puts everything in as few boxes as possible so it shouldn't be nearly that much. If not, that sounds a bit crazy. The other sites mentioned should work. I'd add ECS tuning and outmotoring. Seems best to just shop around.
As for the Military discount, I haven't found anyone who does yet but if you do make sure to mention them.
Also forgot to mention mini mania, bought my last part from them.
I usually try to check a bunch of places. I'll have to add fcpeuro to the list, never heard of them
This has been my experience with WMW too, the shipping price is added up in the check out, but gets corrected after its packed up.
As you can see on their website they were gone for the week at a major Mini event.
They won't be shipping until at least Monday anyway so hopefully they'll see your email and respond.
They have always adjusted and combined shipping in the past so it should be the same for you. I get waiting for a response first though.
And yeah, international shipping costs are ridiculous
He's the last order I need to put in
+1 on all of the vendors listed above. They not only participate on our forum, they are enthusiasts and take a lot of time with advice and suggestions. And they've been around here a long time, with stellar reviews for their business practices. They may not always be the cheapest, but they deserve our business.
Try www.mini2.com if all else fails forum wise. If you live in the US, I suggest British Parts of Utah, I know the owner, and he's pretty awesome. Bought from him for years with no problems
"And USPS is our friend as they are usually the cheapest. So ignore the shipping when you check out as that would be worse case scenario if each item had to ship by itself."
Putting in my order tomorrow morning and supporting the community and WMW. Thanks Way
http://fcpeuro.com
Nik
Nik
We are here if you need anything, and I drive my MINI every day, so I can help you on the specifics.
www.ecstuning.com
If you need help you can always call our sales team or just shoot me a PM.
www.ecstuning.com
Also, for cheaper items, it may make sense to buy two and keep one in "stock" so you can send the other back for replacement and won't be "down".
I'll have to check them out for my next purchase.
DRoc7822
02-11-2017 08:39 AM
