R50/53 teutonik's R53 Auto-X Defibrilation & Build
Old 05-25-2016, 06:52 PM
teutonik's Avatar
teutonik
teutonik is offline
Actually you would be surprised how much weight comes off with tire wear. I was considering using used sets of tires during accel, skidpad and auto-x runs during FSAE comp... it was around 2-3lb/corner on a 10-11lb Hoosier. That's huge inertial reduction for a sub-500lb racecar.
  #27
Old 05-30-2016, 08:13 PM
teutonik's Avatar
teutonik
teutonik is offline
Engine's out for clutch job... Determined my coolant leak was indeed the reservoir (backside, couldn't even tell until I removed it). OCD kicked in and placed a rather large order with ECS Tuning to do a complete cooling and PS overhaul. I hate rusty pipes...
Just deciding whether I should replace the shift linkages while I'm in there... They were freezing last winter, put the play only comes from the mechanism on the trans itself. Hoping to have it ready by the 12th for a break-in/shakedown before my first autox on the 18th.
  #28
Old 05-31-2016, 04:52 AM
MrBlah's Avatar
MrBlah
MrBlah is offline
6th Gear - AX Champion
Hmm not done a r53 clutch, you have to pull the motor ?!?!
on our r56 I just dropped the trans from below, pretty easy
  #29
Old 05-31-2016, 05:16 AM
teutonik's Avatar
teutonik
teutonik is offline
Not needed at all... I wanted to reseal the whole engine.
  #30
Old 05-31-2016, 05:39 AM
HaveATank's Avatar
HaveATank
HaveATank is offline
I want with 17 as well my tire wheels weigh about 48lbs.
  #31
Old 05-31-2016, 08:51 AM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
Thanks for the order.
I would do the shifter linkage while you have it out and easier to get to the underside. Then you can slide out the exhaust heat shield and do them to the shifer box. On the cables PM me the VIN and what the top side shifter lug looks like, black or nylon in color.
  #32
Old 05-31-2016, 09:03 AM
teutonik's Avatar
teutonik
teutonik is offline
That's what I'm thinking... I'll PM with the details when I get home from work. Any possibility I can add it to my order?
  #33
Old 06-09-2016, 04:39 PM
teutonik's Avatar
teutonik
teutonik is offline
Thank you ECS!!! Formula 1 may be in town but I'll be working on my Mini this weekend!
  #34
Old 06-10-2016, 05:27 AM
You are welcome, looks like some goodies.
  #35
Old 06-13-2016, 03:38 PM
teutonik's Avatar
teutonik
teutonik is offline
Lots of of work done... engine trans is back in the car, with the clutch pedal feeling a heck of a lot lighter than before. Currently stuck on a seized inner ball joint that won't come out even with a 12-ton press (broke my ball-joint tool before I decided to cut the joint off). Will need to put some heat into it...
  #36
Old 06-13-2016, 03:39 PM
MrBlah's Avatar
MrBlah
MrBlah is offline
the ball joints that bolt onto the arm? I have a new set in the garage waiting to go on, I did need an excuse to buy a press
  #37
Old 06-13-2016, 03:47 PM
teutonik's Avatar
teutonik
teutonik is offline
Ball joint for subframe -> control arm.... yours might not be that bad. What I'm doing is last resort method. I'm dealing with an original ball joint with 130,000 miles and road salt during the winter. I used the same chop and press method on the second arm only because I broke my ball joint tool on the first one.
Although, if that's your excuse to buy a press, I'm not stopping you. I'm a tool-buying addict...
  #38
Old 06-13-2016, 08:41 PM
teutonik's Avatar
teutonik
teutonik is offline
So, onto plan B and a trick I've picked up along the way. Heated the area around the ball joint with a Mapp torch and dunked it in cold water to create a thermal shock in the joint. It did the trick, but only enough to need 11.5t... That last pull was scary and I've had 20t presses flexing with VW wheel bearings.
Of note, are the oil cooler coolant pipes normally unpainted from BMW/Mini? I just found it weird the one I rec'd was not...
Pics from the weekend:
Plastic bushing had worn away and reshaped the pin as well.
Subframe out for new PS lines and bushings
Attacking the shift cables. Exhaust butchered by a PO.
Everything except T-stat and housing... At least I have a bill indicating when those were changed so I was able to make an educated decision.
75% back in the car...
  #39
Old 06-14-2016, 07:26 PM
teutonik's Avatar
teutonik
teutonik is offline
Small side project that I was able to get done with contacts at work. Strut reinforcement plates... 5 mins of CAD work, laser cut and plated.
  #40
Old 06-20-2016, 05:22 AM
teutonik's Avatar
teutonik
teutonik is offline
Job done and car is running... sort of. I now regret not buying a new t-stat housing and gasket. Started filling coolant and it started pooling in the valley of the housing... derp. Need to have it running this week to go to my friend's wedding.
  #41
Old 06-21-2016, 06:19 PM
teutonik's Avatar
teutonik
teutonik is offline
I am an idiot. /thread
Rec'd my new tstat and realized that I botched the previous install for a second time. Getting too impatient... I just want to drive it again!!!
  #42
Old 08-19-2016, 05:46 AM
teutonik's Avatar
teutonik
teutonik is offline
A quick update... been travelling for work a lot, but got the up and running in time to drive to my friend's wedding in NY. In the process, I have sorted the CEL and a few other miner problems (even a partial clay bar cleaning).
I am starting to feel that the trans is the only weak link left. Does anyone make rebuild kits for these things, or am I going to have to get creative?
  #43
Old 11-15-2017, 09:53 PM
teutonik's Avatar
teutonik
teutonik is offline
Reviving this... I've been spending quite a bit of time on the road for work and my 1984 Rabbit GTI racecar build took on a life of it's own (as well as building my buddy's K20 Civic EK track car) last winter. The R53 has been my daily driver and have managed to put on close to 20k miles in the last 18 months. It might not be a lot, but it must be noted that I have also been away from home for at least 24 weeks in that span. And I have a 10 mile commute (round-trip), so there has been a lot of extra-curricular driving. I love it to death. An incident or two along the way (including losing the battle with a city bus, forcing me into a pothole at 2am and bending a strut) but it keeps giving me a silly grin every time I drive it.
Realizing that if I want to make it a true autox project car, I needed a new daily driver, so the driveway is now shared with a '17 Golf. Anyways, it's off to storage for the winter... I have big plans for it, including a sunroof delete, interior strip, battery relocation, suspension work and a track support trailer system.
Pics
2am pothole...
Yup... carnage.
Progress.
  #44
Old 11-16-2017, 07:51 AM
Minibeagle's Avatar
Minibeagle
Minibeagle is offline
Keep at 'er. Following your thread
  #45
Old 11-16-2017, 09:48 PM
teutonik's Avatar
teutonik
teutonik is offline
Thanks!
Do you do any MCO events? I might venture over there with the CADL cross-over event (work schedule permitting).
I plan on selling my 17s and Direzzas when the time is appropriate. Great tires and great, light wheels, but just too much for the **** roads around here. I have acquired, possibly, my autox/track wheelset. Our local meth supplier, erm, Perry Auto, hooked us up with a group buy-in on a set of track wheels. From memory, they're flow-form construction, 15x8, ET28 and around 10lb ea. Not bad for $400 CAD (300USD at the time). I had originally purchased them for the GTI racecar, but I think the Mini will get them instead. Undecided on tires for now... leaning towards RS-4s.
  #46
Old 11-17-2017, 05:42 AM
MrBlah's Avatar
MrBlah
MrBlah is offline
rs4 wear like iron. I had 30 HPDE sessions on mine and they started to chunk, still lots of tire left
  #47
Old 11-17-2017, 07:05 AM
Minibeagle's Avatar
Minibeagle
Thanks!
I'm a very active MCO member: I'm part of the autocross timing team and participate in as many events as possible every year. Have also a few CADL events (PMG) and did my first time attack at St Eustache this summer. I also do HPDE events: got 4 or 5 in this year.
I'm currently running 16x6.5 SSR C-types with RS4 tires. Used them for autocross and lapping. Like Mega72 said, they wear like iron. They are a great all-around performance tire. I'm thinking of getting a set of 15x8 wheels (most likely 949 Racing) that will be dedicated for autocross. I'm also thinking of getting either coilovers or Koni Yellows with Swift springs over the winter to upgrade my stock suspension.
Let me know about your 17-inch wheels if you're thinking of getting rid of them. I might be interested
mejerry
How to
24
05-23-2023 06:46 AM
goin2drt
10-31-2016 07:02 PM
nismo4life
09-07-2016 05:23 AM
aznchica
01-18-2016 06:35 AM
Russell Simmons
01-06-2016 07:38 AM
Quick Reply: R50/53 teutonik's R53 Auto-X Defibrilation & Build
