R50/53 Tune for my R53
Old 11-30-2015, 02:26 AM
rossgo_R53's Avatar
rossgo_R53
rossgo_R53 is offline
Hello I have my r53 2003. With 90kmiles on it. The car has an Alta 15%pulley and a A&E (CAI) and seems very noticeably that it has lost power or torque in the car... my brother has the same mini as me with only suspension mods done to his car and u can clearly see the torque is way more on sense with the pedal and is just "faster" then mine which dosent make since if my car has a pulley on the car.. i don't no if it makes it any faster but it's noticeably slower then his Mini Cooper . Wondering if it needs a tune ? And what a tune is and what they usually go for price wise for these cars..
Old 11-30-2015, 03:24 AM
Kahnfucious's Avatar
Kahnfucious
Kahnfucious is offline
Why would you put a tune on a car that is exhibiting power loss symptoms? Don't you think resolving those issues should be job number 1 before you start tuning and messing with timing and spark etc?
Use the handy search feature - there has got to be 100 + posts on tuning and tuners
Old 11-30-2015, 04:05 AM
N2MINI's Avatar
N2MINI
N2MINI is offline
Check all your belts, hoses, IC connections etc to see if you have a leak which is causing your current problems first..
Old 11-30-2015, 04:47 AM
ZippyNH's Avatar
ZippyNH
ZippyNH is offline
Fix the power loss first...
Many thousands of cars have run a pulley for years, no issues....a tune is just icing on the cake to get an extra couple HP from the same mods...
If your car suddenly seems slower than a Cooper, check the bpv...it might be stuck in bypass....
Old 11-30-2015, 06:41 AM
Helix13mini's Avatar
Helix13mini
Helix13mini is offline
That's sage advice. First fix what's wrong, and then consider performance parts. Performance parts are almost never a solution for a broken car.
Old 11-30-2015, 07:26 AM
IQRaceworks's Avatar
IQRaceworks
IQRaceworks is offline
Check the Bypass Valve....pretty common problem with the R53's. With the motor off......you should be able to reach down and move the little lever arm to open the bypass valve....when you let go of the lever the valve should snap shut with some force. If it's not snapping shut, the spring is broken and the valve needs to be replaced.
Old 01-10-2016, 02:47 PM
rossgo_R53's Avatar
rossgo_R53
Replaced the valve and that seemed to be the problem!! Thank you !
richardsperry
11-11-2015 02:44 PM
minirips2
31
11-09-2015 06:35 AM
AngeloCarrion
12
11-08-2015 02:35 AM
AWOL
11-05-2015 01:57 PM
Tslatt
11-03-2015 09:09 AM
Quick Reply: R50/53 Tune for my R53
