R50/53 Just bought a Mini Cooper S on Sunday!
I've been watching CL like a hawk, and last Saturday I saw an '05 MCS pop up with hard shifts for $2,800. I drove a couple hours and sealed the deal for $2,500. I love the car.
In the past week I've:
- rotated the tires
- painted the rotors
- painted the calipers
- polished the driver's side headlight
- polished both taillights
- changed the spark plugs
- changed the front wipers
- ordered weathertech mats used from CL
- ordered a real cup holder used from CL
- ordered a new "Mini" emblem for the hood
- 17% pulley with belt and tools
- Transgo shift kit
- tranny gasket
- ordered steering wheel control module for aftermarket stereo
I guess that's it for now. I really love the car!
- rotated the tires
- Transgo shift kit
- tranny gasket
Congrats, sounds nice. Post it here in the introduction section.
https://www.northamericanmotoring.co.../1st-gear-114/
Thanks. I'm already on the lookout for another one. Seems my daughter has taken a liking to the Mini.
Rock on! Sounds like you got a smokin' deal! I got my '05 MCS a few years ago and have enjoyed it immensely. Mostly basic maintenance too, I had heard that Minis could be temperamental but Griffer has played real nice. He has been off the road a few days due to some updates(new shocks and struts,Bilstein, new rear sway bar, new ball joints inner and outer, new LCA bushings, front sway bar bushings, upper and lower engine mounts, M7 strut bar, IE fixed camber plates)but will be back to chewing up pavement real soon. One note, my power steering pump recently quit on me due to a shoddy design on the original but it is a known issue and Mini will replace it Free of charge up to 150,000 miles or 15 years(I think, there are several threads on here about this) in case your steering gets wonky on you. Enjoy!!!
Even with that being said, it was a good deal to me. Once it's shifting right I'll let my 14 y/o daughter drive it around the block again (practicing for Lerner's permit) and likely I'll drive it until she takes over ownership in a year.
Congrats - The 6 speed auto is actually pretty good. I had a local transmission shop rebuild the valve body to a good result. We have a 2005 - Feb build MCS. There is a thread here about the transmission. Make sure you use at a minimum Toyota 3309 spec fluid. $5 at a Toyota dealer. This is also the same transmission in Partswagen GTI's ( 09G ).
I also recently replaced the transmission mount = $151 at the dealer, but it made a difference - All 3 mounts are new - I go thru the fluid filled right mount every 18 months, the lower dog bone one - every 5 years is a good time to check it, and the trans mount - first time at 10 years, 116k.
Have fun.
RY
Have fun.
RY
Have fun.
RY[/QUOTE]
Depending on how handy you are(and your tolerance for DIY) the engine mounts(except for the trans. mount) are easy to swap out, seriously about a max of a 1/2 hour job on each one, even for a novice should not take much longer. You will know it is time to change the right when you see the fluid leaking(black, sticky), you will need an E12 socket but there are lots of DIYs on here, YouTube, Pelican Parts has lots of great walk-throughs(with pics=awesome!) I have not done the transmission mount on my 2005 yet(I need a break from wrenching for a couple weeks) but it just involves taking off a few things to reach it whereas the other 2 mounts are pretty straightforward....best of luck...motor on!
Have fun.
RY[/QUOTE]
Have fun.
RY
Have fun.
RY
Have fun.
RY
Have fun.
RY
Depending on how handy you are(and your tolerance for DIY) the engine mounts(except for the trans. mount) are easy to swap out, seriously about a max of a 1/2 hour job on each one, even for a novice should not take much longer. You will know it is time to change the right when you see the fluid leaking(black, sticky), you will need an E12 socket but there are lots of DIYs on here, YouTube, Pelican Parts has lots of great walk-throughs(with pics=awesome!) I have not done the transmission mount on my 2005 yet(I need a break from wrenching for a couple weeks) but it just involves taking off a few things to reach it whereas the other 2 mounts are pretty straightforward....best of luck...motor on![/QUOTE]
Thanks. I'm decent with tools, so I'd be doing 90% of the work myself. The mounts look pretty easy.
Thanks, but I've already flipped it. I'm using the profits to get an '07 Convertible Mini Cooper S. That is if the top doesn't leak.
The car is in horrific shape, but I need a winter project. I'll post up a thread when/if I pick it up this weekend. The interior is disgusting. It's as though the owner never once cleaned it out. Smells like vomit. However, it's only got 86K on it and I'll likely get it for $3,900. It runs very strong though and it's manual.
The Good:
- Runs great.
- Shift great.
- Looks great.
- Handles great.
- Only 86K miles with clean Carfax
- One owner.
- Seats in great condition.
The Bad:
- Hood was repaired and needs a partial respray.
- Driver's door looks like someone took a crowbar to remove the door card. A little bondo and respray.
- Bumper lip needs replacing.
- Missing power steering pump duct and plastic splash shield.
- Tiny hole in top.
- Dead CD Player.
- Wheels badly rashed and one definitely pot-hole damaged.
- Car smells like VOMIT
- Door seals are delaminated.
- Rear top seal is degraded.
- Small rough spot on top that I don't believe leaks, but I'll find out soon.
- Need to repaint some interior pieces.
- Door cards need work.
The Good:
- Runs great.
- Shift great.
- Looks great.
- Handles great.
- One owner.
The Bad:
- Tiny hole in top.
- Dead CD Player.
No, it's likely going to be sold in the spring. My daughter now wants a black Saab like her big sister's.
Thanks. We've had very good luck with Saabs. In the past 3 years we've had three, two 9-3 's and a 9-5. I bought a lime yellow convertible 9-3 Aero last year to get me through the winter. I sold it earlier this year.
