R50/53 Bearing ladder seeping? what now?
Old 09-24-2015, 06:26 PM
Nicefeet's Avatar
Nicefeet
Nicefeet is offline
I first must start by say what has been replaced in the last two years.
The crank sensor o-ring
The cam sensor o-ring
The oil pan gasket (twice) The second time I replaced every single bolt with OEM new MINI.
The timing cover gasket and oil pump gaskets. I used sealer as required where the ladder joins the case.
The entire oil filter housing assy
The valve cover gasket
The spark plug well gaskets
All the valve cover bolts were replaced with new OEM MINI
The crank seal (front)
Both timing chain guide plug o-rings
I still have seepage on the lower back edge of the oil pan gasket. It's right below the oil filter housing. The oil filter housing looks dry.
This is really starting to rattle me that this car can't hold oil. I'm starting to suspect the bearing ladder is seeping.
Old 09-24-2015, 06:44 PM
Tylerlanger1's Avatar
Tylerlanger1
Tylerlanger1 is offline
I've done pan gaskets 3 times and they still leak. My only suggestion is checking the oil pan for warpage. Aluminum to cast can sometimes be tricky.
Old 09-24-2015, 06:53 PM
Nicefeet's Avatar
Nicefeet
Nicefeet is offline
If I pull this oil pan one more time this thing is getting a coating of sealer. and sent down the road.
It's always been the same spot that has wetness.
sikamini
Factory JCW Talk (2009+)
06-21-2017 12:29 PM
QuickCooper
12-29-2016 06:46 PM
vulkandino
10-31-2015 08:29 PM
unxpectederror
10-22-2015 12:16 PM
Levers_and_Gears
09-28-2015 04:42 PM
Quick Reply: R50/53 Bearing ladder seeping? what now?
