R50/53 Can I remove the driver's seat without airbag light if I disconnect the battery first
Old 09-06-2015, 10:56 AM
wildwestrider's Avatar
wildwestrider
wildwestrider is offline
I might be removing my driver's seat to take it to a local upholstery shop. Wondering if I can avoid the airbag light coming on, if I disconnect the battery first before removing the seat??
Brian in Austin
Old 09-06-2015, 11:10 AM
Finhead's Avatar
Finhead
Finhead is offline
You need to run a resistor to avoid the light coming on. 3.9 ohm I blieve is what is used.
http://www.minitorque.com/forum/f10/...67/index6.html
Old 09-06-2015, 11:15 AM
Da_Ghost's Avatar
Da_Ghost
Da_Ghost is offline
The airbag system will do a self-check when you turn the key on, so unless you play with the ignition while the seat is out, you should be good.
Old 09-06-2015, 11:30 AM
wildwestrider
So, would disconnecting the battery completely,....insure that an airbag light would not be triggered?
Old 09-06-2015, 01:16 PM
Finhead's Avatar
Finhead
Finhead is offline
Soprry think I read your inital post wrong. IF your not going to be starting or driving the car without the original seat your fine with the battery disconnected. I have had my doors off mine for painting the last week (air bag sensor in the door) without moving the car battery out, put it all back together yesterday and it's fine no light.
Old 09-06-2015, 03:24 PM
David.R53's Avatar
David.R53
David.R53 is offline
It will be fine as long as you leave it disconnected. I just swapped my seats with no lights. Plan ahead on whether you want windows up or down.... I've been caught... I also place a floor mat across the rear hatch latch so it doesn't latch with the battery disconnected.
Old 09-06-2015, 06:06 PM
Da_Ghost's Avatar
Da_Ghost
Da_Ghost is offline
There's still the release cable under the rear seat for that.
Old 09-06-2015, 06:13 PM
wildwestrider
That's good to know. where is it located under the back seat?
Old 09-06-2015, 06:18 PM
Da_Ghost's Avatar
Da_Ghost
Da_Ghost is offline
Middle near the front.
Teh
06-13-2018 02:59 PM
mishanja
06-22-2016 09:59 AM
messyjesse96
08-12-2015 05:51 AM
quality_sound
08-07-2015 09:36 AM
nismo4life
08-05-2015 08:31 AM
Quick Reply: R50/53 Can I remove the driver's seat without airbag light if I disconnect the battery first
