R50/53 Need a new transmission - please help!
Old 08-26-2015, 12:47 PM
MiteyF's Avatar
MiteyF
MiteyF is offline
'05 R50 with the 5 speed, 160k miles
Driving to and from work today my transmission popped out of 5th gear a few times. Came home and did some investigating... turns out I blew a hole in the housing somehow, right at the top, to the side and below the battery box
Seeing as I'll need a whole new transmission one way or the other, and since the car's got quite a few miles on it, I'd like to spend as little as possible without taking any unnecessary chances as to reliability etc.
First question - There's a trans from a 2011 Clubman S on CL right now, assuming it's a manual (seller hasn't called me back yet), would this fit?
Really, what are my options? I'd just as soon put in a newer transmission, 5 vs 6 speed doesn't really concern me, I just want something that's unlikely to give me problems down the road.
Any advice is welcome here, I'm still fuming at the prospect of installing a new trans before the snow hits and I can't ride my motorcycle any more.
Old 08-26-2015, 12:57 PM
MiteyF's Avatar
MiteyF
MiteyF is offline
So the trans in the '11 is the 6 speed manual... only 20k on the car, and he provided me with the VIN. He only wants $600... so, will it fit?
Old 08-26-2015, 02:00 PM
Shawnnn's Avatar
Shawnnn
Shawnnn is offline
Highly doubt it. Completely different engine
Old 08-26-2015, 02:49 PM
MiteyF's Avatar
MiteyF
MiteyF is offline
What year did the engine change?
Old 08-26-2015, 02:59 PM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
Vendor
May have some luck sourcing a used one on www.car-part.com. Cheapest I found though was about $1295. At my old shop we've sourced quite a few used transmissions from there for customers. I think I saw someone mention that WMW (Vendor on here) has a few part outs and has parts available for specific MINI's. Might contact him and see if he has one laying around that'll work for your MINI... Good luck.
888.280.7799 | 6am - 5pm PST
Old 08-26-2015, 03:18 PM
MiteyF's Avatar
MiteyF
MiteyF is offline
Not a chance I'll shell out $1300 for a used trans... either way I really appreciate the tip.
There's another 6 speed on the local CL from a 2002 for $800 that supposedly works perfectly, although there's obviously no way to know.
So the question remains, what years 5 or 6 speed WILL fit?
Old 08-26-2015, 03:23 PM
Shawnnn's Avatar
Shawnnn
Shawnnn is offline
06 was the last year except for convertibles
Old 08-26-2015, 05:07 PM
5904's Avatar
5904
5904 is offline
You'd be much better off finding a correct 5 speed for a direct swap. I don't know if a 6 speed will even work but at a minimum you would also have to change out the shifter and linkage.
gknorr
12-26-2016 09:38 AM
vulkandino
10-31-2015 08:29 PM
SJ-R50
10-28-2015 08:39 AM
10-01-2015 12:13 PM
B1mm3r101
10-01-2015 06:22 AM
Quick Reply: R50/53 Need a new transmission - please help!
