R50/53 Crankcase breather hose help needed
I need to replace a crankcase breather hose on my '04 R53. It is the molded 1/2" ID rubber hose that runs from a fitting on the valve cover next to the oil filler cap into a fitting on the big rubber intake hose between the air filter and the throttle body. It's about a foot long.
I can't find one online and the parts guy at the MINI dealer wasn't much help over the phone. If I can get a part # my local parts guy can get me one.
It’s it the one that goes from the Pcv valve to the supercharger? Also does anybody know if you can get the hose that goes from one of the Evap system valves to the lower supercharger intake by itself? It’s the lower house in part number 11667550007
Thats the part here: Its a hard line that is heat shrunk, not on its own. Maybe because its heat shrunk. We have an aftermarket which is the OEM supplier for less.
https://www.ecstuning.com/Search/Sit...h/11667550007/
The price is 58 aftermarket OEM Vs the genuine MINI is 141
I dont know if you saw that.
Dont have anything else.
khnitz (09-01-2022)
