R50/53 Temp guage
Temp guage
Yellow-ha! Fellow mini'ons lol. Just a quick question here. Does the r53 temp gauge needle tend to go below the middle line? My mini does this only when I'm in the freeway. Stop and go traffic stays on mid line no more no less. Before I had a clutch job It wasn't like this. Also my other car don't as well. Is this norm?
...Hmmm? Both of my R53 run just under the center line.
Motor on!
"Now can't get the name "MINIYellowHaHa" out of my head..." Its a summer camp out in the mountains hidden away from the eyes of lowered VWs and tricked out Audis , where MINIs can run and play on an asphalt ribbon of fun...
Motor on!
From what I have heard the gauge is really more like an idiot light in that it stays in the middle unless the engine is overheating and the it moves to the top of the range. Mine never varies from the center once warmed up. On my '75 the gauge fluctuates based on factors like outside temperature and load- like a real gauge should.
Cool! I actually thinking It's because I'm having a good air flow in the car that sucks in the cool air into the engine bay which makes the engine run cooler. And probably the recent clutch job helps the motor to have less stress. So It cools down a bit. Anyways Thanks guys for sharing. Motor on minions!
Good question. Well the thing is The last time I checked it spins with the a/c on. But unfortunately now that my ac is not functioning I have no idea on how to check it. For some reason F5 fuse located next to the drivers footwell is out. Although the fuse is looking fine. my fuse tester weren't lit on that f5 slot everything else in there is okay. Even tried to swap with known good ones with no luck. Hmm..
After you confirm that they both work, you should also start your car with the bonnet open and a flashlight, watch that it comes on as the car warms up, if you let it idle, it should eventually come on even without the AC, and the high speed should come on after a while as well.
R50/53 Help please.. Odd issue.
PsychoRallye
21
02-17-2019 06:08 AM
