R50/53 eBay Radiators?
Compare the names (if given) to the ones on rockauto.com
They are typically the same ones the local bigbox suto parts stores sell....
My one concern might be getting the right part...many non MINI specialist think an S is a trim level...not a different motor, and think the same parts fit everything....
For me...I'd spent the extra $20-30 and get one from rockauto, and have a known item, with a known seller I can go back too if I have issues.....
I agree, some sites will list the incorrect part for your model so make sure you're comparing part numbers with the one you're looking at. For MCS 2002-2008 Part # 17-11-7-570-489. If you need help with the install be sure to check out this DIY here.
888.280.7799 | 6am - 5pm PST
Depends on the brand name. I've had a full aluminum radiator crack on me before with only 20k miles on it.
Is there a difference between manual transmission and automatic? eBay seems to think so...
Opinions of CSF? Or is the upgrade even worth it in a stock setup? I am interested in upgrading if what they said is true about the aluminum radiators keeping the engine much cooler, but if that's just hogwash then I save my money and just get a stocker. It does seem to get awfully hot in these tight engine bays...
