R50/53 bringing back the r53
Old 09-02-2015, 06:24 AM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
Originally Posted by The_Kid
Shes lives!!!!!!
Awesome.
  #102
Old 09-02-2015, 07:09 AM
batrugger's Avatar
batrugger
batrugger is offline
Glad to hear you got it started. The DDMs are notorious for not working with silicone tubes and really the best option is your stock intake hose if your going to use it. I have a brand new DDM that was given to me, but since I just had the K&N chromed and didn't want to use the stock hose I didn't use it. The engine damper on the passenger mount was made by Texas Speed Works and there is a lot of info in this site about them. We had one of those too and it worked great, but after going all out on the engine bay it was removed due to appearance.
  #103
Old 09-02-2015, 07:15 AM
The_Kid's Avatar
The_Kid
The_Kid is offline
I've seen the ddm used with silicon intake but seems that the o ky one that works is the samco. Still a little trimming neccesary. I may just order a stock hose from Way for now to finish it up and later in down the broad 're look at the silicone hose . The urban camo from Detroit tuned is looking pretty wicked tho.
  #104
Old 09-02-2015, 07:27 AM
Spencer Roper's Avatar
Spencer Roper
Spencer Roper is offline
That urban camo does look good!
Glad you got those house situation kind of figured out..
It's the home stretch!
  #105
Old 09-02-2015, 07:30 AM
The_Kid's Avatar
The_Kid
The_Kid is offline
Yea just debating on whether I want to try the samco. The venair kinda gave me a bad taste so far. And since I'm out the $88. Do I want to spend another hundred or just go with Way and spend $30 on an oem hose for the time being. At least till the bad taste goes away. Sounds like a plan
  #106
Old 09-02-2015, 07:36 AM
Spencer Roper
Since its not a hard job you'd want done the way you'd want it to stay (ie PITA location) I totally agree.
I'm sure you want to just get on the road and WMW dies have some fast shipping.
Just don't use minimania.......I've been waiting on a skid plate for 2 months now...not even a courtesy email.
Other than fluids.....it's fully ready to go ?
  #107
Old 09-02-2015, 08:05 AM
The_Kid's Avatar
The_Kid
The_Kid is offline
yea i understand the PITA postition. however i did order a stock hose, as i looked at venair hose again and im not happy with how tight it is up against the intercooler horn, and the breather hose or the inlet to the intake box dont line up at all. its a nightmare. so for now im going back to stock. i just put one on order from WMW. so hopefully be here in a few days.
and as far as i know other than fluids, all i have to do is put the front end back together, im about to start messing with that now. it will be nice to see it back on 4 wheels. working over the road like i was has certainly drug this project out, but then again it was a project. its nice to be in the home stretch.
  #108
Old 09-02-2015, 08:28 AM
batrugger's Avatar
batrugger
Make sure you use OEM coolant or you can get this:
Amazon.com: Pentosin (PF-NF-1500ML) Antifreeze - 1.5 Liter: Automotive Amazon.com: Pentosin (PF-NF-1500ML) Antifreeze - 1.5 Liter: Automotive
I've been seeing a lot of people using green lately and that's not good.
  #109
Old 09-02-2015, 08:55 AM
The_Kid's Avatar
The_Kid
The_Kid is offline
Will keep it in mind. I have to run dexcool in my duramax. So I'm aware of checking for the right fluid.
Getting the front back together and I notice this plug. However its too short to go anywhere and I don't remember unplugging it. It's located on passenger side as well as driver side
  #110
Old 09-02-2015, 09:00 AM
The_Kid's Avatar
The_Kid
The_Kid is offline
Disregard that last message. That connector goes to the horn on each side..
Here's the progress thus far.
Cooking system back on and ready.
The bumper support and bumper back on and everything wired up. Now just a few finishing pieces am d out wheels back on
  #111
Old 09-02-2015, 09:27 AM
The_Kid's Avatar
The_Kid
The_Kid is offline
Excuse the mess. But now just need to add coolant and do a test drive
  #112
Old 09-02-2015, 11:11 AM
Grizld700's Avatar
Grizld700
Grizld700 is offline
Looking good!
  #113
Old 09-02-2015, 11:20 AM
The_Kid's Avatar
The_Kid
The_Kid is offline
Originally Posted by Grizld700
Looking good!
thanks. looks even better outside the garage.
i did some research as far as coolant. and found a few locally that could be bought. i ended up getting the prestone extended life. which meets the critical points as far as european cars and minis in general. so that is in the car now and i have done an initial test drive through the neighborhood.
i need to let the car cool down and check coolant level. and as of everything else, adding the the power steering fluid the pump is working where it was just empty before. so thats good news. and the only things i heard were a small exhaust rattle at low rpm upon start up and initial take off, and there was small sound coming from the dr side wheel well lit a dust plate making contact with the rotor. other than that need to blow the cob webs off and brake the dust of the brake system.
sure was a fun test drive. im even more in love now and that supercharger wine is so nice!
  #114
Old 09-03-2015, 06:09 AM
Yep +1 . MINI Blue Coolant or aftermarket version of it, we carry the Pentosin Blue coolant also. mix 50/ 50 with distilled water and you are ready to roll.
Also congrats on getting it all done. I bet you cant wait to clean and detail. Its a new MINI now.
  #115
Old 09-03-2015, 06:16 AM
The_Kid's Avatar
The_Kid
The_Kid is offline
I ended up using the prestone extended life as from the research for coolant I found that it had the same characteristics as what mini calls for. So went for that to get it out of the garage and do the out of the state inspection and titling done. Hopefully it won't hurt , but from what I found on various forums and from a mini owner who emailed prestone to verify that is was amine/nitrate/phosphate/silicate free. However this coolant is green :(
  #116
Old 09-03-2015, 06:18 AM
The_Kid's Avatar
The_Kid
The_Kid is offline
Should I be looking at draining and installing new coolant ?
  #117
Old 09-03-2015, 06:27 AM
You should be ok, I know using other coolants might not be safe for head gaskets and other parts, that don't meet the requirement. I have not seen any very long term issues with that one, but its good insurance on the Blue. Coolant is not that costly between the Blue MINI coolant and other ones. I would make sure it meets all the same formula and requirements and should be fine. We dont carry it so I cannot comment on it. I have always used the Blue Coolant with no issues.
  #118
Old 09-03-2015, 07:45 AM
The_Kid's Avatar
The_Kid
The_Kid is offline
i will probably end up flushing the system, along with all fluids.
on another note. i keep getting a check filler cap light. but it comes and go's.
and i went to open the rear hatch today and had water dump out of it. as the mini sat in the drive last night during a rain. where could the water be getting in at?
other than that, the thing is a pleasure to drive and more power than i expected it to have. it really turns on once you get past 3500rpms!
  #119
Old 09-03-2015, 08:02 AM
This is Gen 2 , same cap a gen 1 , they now have the blue color end. Not green anymore, the gasket on it can fail or the locking function.
https://www.northamericanmotoring.co...-location.html
Drain tubes / or setting in the sunroof tray then draining back.
Also the tailight gasket
https://www.northamericanmotoring.co...runk-pics.html
https://www.northamericanmotoring.co...in-my-car.html
Also is it in the floor / near the battery ?
https://www.northamericanmotoring.co...-problems.html
  #120
Old 09-03-2015, 08:49 AM
The_Kid's Avatar
The_Kid
The_Kid is offline
just in the hatch panel itself. so i assuming it will be the third brake light as the culprit. as i have read that being the problem with these.
  #121
Old 09-03-2015, 10:05 AM
The_Kid's Avatar
The_Kid
The_Kid is offline
We are mobile!
  #122
Old 09-03-2015, 10:35 AM
Spencer Roper
Wow looking great
Have you discovered the leak yet?
I'm sure your loving that supercharged wine !!!!
+1 on ECS info It could still be channeling through sunroof as well and coming out by third brakelight
  #123
Old 09-03-2015, 11:52 AM
batrugger's Avatar
batrugger
Congrats, now you can have some fun
  #124
Old 09-03-2015, 01:47 PM
ZippyNH's Avatar
ZippyNH
ZippyNH is offline
Congrats!!
Long road back, but you did it!!
  #125
Old 09-04-2015, 07:07 AM
We are mobile!
Looks great, now all ready to go.
surfblue
10-24-2018 01:20 AM
JPMontes3
08-23-2015 01:26 AM
08-12-2015 01:24 PM
08-11-2015 11:58 AM
08-07-2015 08:02 AM
Quick Reply: R50/53 bringing back the r53
