R50/53 Best fluid for transmission
Old 07-05-2015, 08:57 AM
jc8825's Avatar
jc8825
jc8825 is offline
What is the best MTL for the 6-speed? I am considering going to GM Sychromesh Friction Modified MTF as it did a fantastic job smoothing the shifts in an older higher-mileage EF Civic I had years ago, but I am always looking for suggestions. I have also heard that a heavier weight fluid works well, such as the MT-90 stuff from Redline. I ran the MT-90 in an EP3 Civic I had in 2005, and I never had a shifting issue with that one either, but it was a low mile car as well.
Old 07-05-2015, 12:13 PM
RogueMini's Avatar
RogueMini
RogueMini is offline
Redline synthetic MTL 75w80
Change it every 30k miles
Old 07-05-2015, 02:48 PM
jc8825's Avatar
jc8825
jc8825 is offline
Great, so GM Synchromesh (Equivalent to the Redline MTL and available locally) will work fine. Thanks.
I don't know when the fluid was changed last, but it is due based on the feel of the shifter.
Old 07-05-2015, 07:16 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
Been using the redline MTL for a long time and it works great.
http://www.waymotorworks.com/redline-mtl.html
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
Old 07-05-2015, 09:16 PM
Rrotz's Avatar
Rrotz
Rrotz is offline
Red Line MTL 75w80 is what I'm changing my stock fluid with when I'm getting the clutch changed.
Rainforest_Elf
09-15-2015 12:11 PM
09-10-2015 03:36 PM
Tires, Wheels & Brakes
09-10-2015 12:27 PM
rob76turbo
GP Talk (2006)
09-07-2015 12:28 PM
Quick Reply: R50/53 Best fluid for transmission
