R50/53 Passenger CV boot axel issue
Took a pretty stiff turn and hit a good bump... passenger right cv boot axel snapped and sent the car grinding and skidding all over the place.
Had it towed since it was late at night
Mechanic said they can rebuild the broken one for 275 + install labor
Is this a common issue with these 1st gens? suspension upgrades maybe in the future
It happens, not super common thing. You can pick up a new replacement unit with new boots and all for 100 ish, on rock auto i think. Then just pay some one for labor or if your good with tools do it yourself. After taxes and shop labor you are prob gonna be in the 500 dollar range or more with your mechanic.
update
Picked up the r50 from mechanic shop today and they put in new replacement passenger CV axel .
Looks good.
Passenger area now has bad vibration when decelerating and braking it gets even worse ... happens when in gear and when not ..
Same Mechanic say it's the lower ball joint.... did this guy just not do something right or did I bust some other stuff up along with CVT .
What bolts should I investigate to being loose etc .... possible bent control arm?
Looks good.
OEM is the best option unless you're wanting something more aggressive. Take a look here under suspension. Might find a tech article that can be of some assistance with the repair.
-Luccia
-Luccia
888.280.7799 | 6am - 5pm PST
I did my brother's mini LCA last weekend. We had the subframe out already. we were doing whole bunch of work (new clutch, 15% pulley, main crank pulley, oil pan gasket and so on) It took us a couple of hours to replace the bushings. we rented the ball-joint tools from advance auto. (Powerbuilt Tools Ball Joint Service Kit (10 Piece)). It fits perfectly. you will need at a minimum access to a bench vise-grip and an impact wrench. check pelican website on how to remove subframe. While in there, if you have the subframe out. ball-joints, front sway bar bushing, steering rack bushing.
RACEnSK8
08-31-2015 01:08 PM
speedbird_1
08-15-2015 04:44 PM
