R50/53 Cranks but won't fire
Out of nowhere My '04 S won't start. I drove to work today and everything was fine. Got in it this afternoon and it cranks fine, strong battery and starter but it will not fire. Nothing, no sign of firing.
If this car was from the '60s I'd say the coil wire was off or I was flat out of gas. Since it's from 11 years ago, the coil wire doesn't apply but fuel could be a problem. It does have a quarter tank though.
My first thought is the fuel pump quit. Does this sound familiar to anyone or am I barking up the wrong tree? How would I go about checking? I don't notice any wrong sounds or lack thereof.
Any input greatly appreciated
I finally got to it today. It has spark. I ran out of time but I'm thinking my first thought of fuel pump was accurate. I'll check more tomorrow.
Do the fuel pumps have a tendency to quit out of the blue? I'm at 87K miles.
Car won't run 101: Gotta have fuel, gotta have spark, gotta have spark at the right time.
On a modern car like this the spark at the right time is rarely an issue so it does point to fuel pump.
Pump Inspection
My curiosity was killing me so I took the old pump apart to try and see what went wrong. I got the motor/pump assembly out and it is quite stout. It turned freely and felt fine. I put 12 V to it and it whirred away like nothing ever happened. I put everything back together and the same thing.
I'm sure it would pump fine now but for how long until it freezes again?
I think these motors tend to stop on a dead spot and then won't start next time.
It's frustrating that nobody will sell you just a new motor/pump and you have to buy the entire assembly, most of which is perfectly fine.
heat tends to cause one or more of the solder joints fail in the motor/windings of any fuel pump to fail., or ANY electric motor to fail..same happens to the insulation on the wires in the motor....causes a "dead spot" where IF the pump stops in that spot, it is stuck...that is why banging the pump/fuel tank with your hand to jostile it works...same trick as hitting a starter with a hammer to get a few more starts....
wildwestrider
11
01-29-2016 05:06 PM
dutchhome
09-30-2015 07:17 AM
daviday
09-25-2015 01:31 AM
Nicefeet
09-24-2015 06:53 PM
