I would not recommend removing them. Pulling them will eventually strip out whatever you use to replace the weld. I wanted to do the same with mine but decided not to.
I took the first piece off. Accidentally drilled through one of the holes but it doesn't matter since I can cover it up with plastic filler before I paint
IIRC, the coating on the dash and door "rings" is not what you think it is. I think it's some sort of vinyl coating or wrap. I see that others have painted theirs, but make sure you first put down a coat of something that won't cause that original coating to wrinkle/dissolve/worse.
I painted my dash in a hammered finished paint and the rings in Chili red which the local auto paint house made up for me. I did sand the original finish off before priming and painting. See my Gallery.
I had a passenger accidentally rip out the door pocket (no, it's not a door pull ) and re-attached it with a glue gun. Been fine for years, and I don't expect any issues. IIRC, others who removed the trim used this method.
The huge ring trim (the one that circles around the whole panel) does look like there's a vinyl coat on there. I'm still thinking what to do with it. Sand + primer + paint? or just use something like plastidip? I personally want to stay away form plastidip if i can.
Are you only going to take the ovals/speaker covers off and not the actual pull/armrest bars off? In that case - I guess silicone will do. I was thinking that you are removing the armrest bars too.
If you look at the pics, I've taken everything apart. I just start putting back the easier stuff first
So everything is back into place. So far so good. My suggestion is to use a good amount of silicon for the bottom piece. The reason is because the top piece is held up with bolts but the bottom isn't. Putting more would be safe just incase someone decided to close the door pulling the "storage" piece.
1) Did you simply drill out the welds? What size bit?
2) Can you can the ovals off without removing the bars?
Ok, actually three questions.
1. Yes just drill out. Be careful not to drill to much otherwise it will go through the panel. I used the biggest drill bit I have. Don't remember the size but anything close to the size of the plastic welds will do. After all is drilled then push it through the drilled holes with a screwdriver until they pop out. The bottom piece has 3 long plastic welds. Using a cutter should be able to get them off but be cautious not to cut yourself.
2. Yes but I removed everything because it's the bars on mine that are worn
Originally Posted by Eric_Rowland
How did you prep?
What did you paint it with?
(that's a total of five questions if you're keeping track. )
I just found whatever is in the house to prep. Sand with 320 grid, primer then texture paint. The texture paint is aweful because they would wear prematurely when touched all the time but that's all I had at home at that time.
Nice job. I am wanting to do the same thing except I want to wrap my trim in real carbon fiber and repaint the actual door pull in gloss black. So my questions is this:
When you removed the door trim was it 3 pieces or 2?
In other words, was the top arch attached to the door pull or are those pieces separate?
