R50/53 Warning on Monroe strut mounts
I just posted on this in another thread. Avoid them like the plague. The factory strut mounts are way more expensive, but you won't be re-doing the job in three months. I finally learned my lesson after eating a few warranty jobs.
Thanks Helix, is there a good place to buy the better mounts, or another brand such as moog? Also saw your other post mentioning your M coupe. Just sold my m roadster (to enthusiast auto), and bought the mini!
http://enthusiastauto.com/qsearch/?i...1#.VQGhZ47F98E
We had a customer install the Monroe mounts previous to visiting us, we put the car on the lift and the mount literally fell apart. Bearing came out of the rubber isolator, as Eric said; pay more now, save more later.
Many vendors have the MINI aftermarket strut mounts on hand, if Eric doesn't have them on hand we have them in stock and would be glad to help out.
Nick
Detroit Tuned
Nick
Detroit Tuned
They are typically $122 each from the dealer http://parts.miniofkennesaw.com/prod...306758309.html
I would consider getting reinforcement plates while you're at it to avoid mushrooming on the towers, but they can be installed from up top and can be done later.
Have heard from a couple people about the Monroe ones.
We have the mounts here, used the lemfoder ones with no issues. : 3/2002+ gen 1
http://www.ecstuning.com/Search/SiteSearch/31306778833/
Did you get them replaced yet? Sorry to hear both are bad. I replaced them in pairs before, just to be sure , a good visual at the top for the cracking let you know.
Good luck.
Good luck.
Good , thanks for the update.
Replaced the Monroe mounts today with Lemforder mounts from ECS, good thing i bought a spring compressor from harbor freight. First thing that i noticed was the Lemforder mounts upward deflection was roughly half that of the Monroe--definitely a good sign. Unfortunately this didn't solve my creaking upon accel/decel, i am wondering if a bushing is rubbing. I did pressure wash the underside of the car when i replaced a burst PS hose (about the same time this starting happening)--anyone have any ideas? The only way to reproduce the noise (pass-side front), is driving the car. Pushing up/down on the front of the car = no noise.
I have found that Moog aftermarket sway bar end links will rub on the passenger side axle. They were made too thick which they try and use as a selling point, but it don't mean crap when it don't work. This cause my car to making a rubbing sound under decal and accel at random times.
Also is anyone else finds this thread avoid Moog upper strut mounts, those are garbage also. Mine didn't even last a couple of months and all I got was a finger from Moog and Rock Auto
Would you say the same for kyb, Sachs or lemfoerfer?
techgearpro
R60 :: Countryman Talk (2010-2015)
07-23-2019 07:09 PM
embiggenedmini
10-15-2015 12:36 PM
ClayTaylorNC
08-10-2015 09:19 PM
