R50/53 Checkmate Build Thread
#101
They are from m7 tuning they have quite a few styles on their website. They are the only ones I can find that make them anymore
#104
I fit the R56 side skirts not the R53, and I really don't have any pictures of when I did that part of the build, but I was working along side a body shop on it, and it took about a month to fit them to an R53. The length of the skirt is about a 1/2 inch overall to short, the top sill doesn't fit right without being cut, the top edge doesn't fit the body right, the clips to hold it to the car have different bracketing, etc. I would honestly not suggest it as it is a pain in the butt mod really. We had to modify every side of the skirt but the bottom in some way and it still didn't match up perfectly. It did turn out nice, BUT it is by far not just a weekend mod, or a easy mod, that is the reason there are only 3 I know of that did it before me.
#107
#108
#109
#111
Yeah I did immidiatly after I searched it, the problem is I have a 2006 so its not under the warranty. Also, I literally have 2300 miles on this pump I just replaced at the beginning of the summer when I was doing the front subframe work from NAPA, I really just don't want to have to take the entire from end of the poor car apart again because of another crappy pump.
#112
Don't worry, I just swapped mine out. I wanted brand new and paid dearly for it. But it took me 45 minutes start to finish to swap out the pump. You don type have to drop the subframe to get it out. It slides out thru the front after taking out the bolts, wire, and disconnecting the hoses. It really is the easiest swap I have done on this car.
#114
http://www.pelicanparts.com/techarti...eplacement.htm
http://www.billswebspace.com/MiniR53PSPFanDuctDIY.htm
#115
#116
Those jack points get knocked. Just mount up the new one and push the plug through and your done. Mine all all chipped up over the years from rocks, need to replace them, but did not loose one for 250K miles.
#117
Yeah I know what took mine off it was the weights off a wonderful orange Michigan construction barrel, I was getting on the highway a few weeks back early in the morning so it was dark and the barrel was in the between lanes so I didn't move over and then hit the weights of it that I didn't see till 2 second before that were in my lane, my front tire went directly over then and it took out the front clips on my skirt so I think that's where the Jack point went too
#119
So the cold weather is starting coming in an I have steering pump issues going on right now fighting with NAPA over the power steering pump so the MINI is done for the season. So now its time to start the agenda for this winter. I am planning on doing the tie-rod ends both inner and outer as they are seized up, and put a ATI harmonic dampener on as the crank pulley is starting to go bad. Also I am going to try to add a RMW header and tune as I have the motor setup like I want.
#120
Ok got some time over Thanksgiving break to wrap up the power steering pump, put on a ATI harmonic dampener, and replace the tired ends. I also switched my coolant and power steering tanks to the new ones that M7 sells, which look really good but are kinda a pain in the butt to install. I gave the MINI a good wash and put it where its gonna be for the next months till the warm weather returns to michigan. I have a cover coming for it too.
#123
#124
" 1973 DeTamaso Pantera GTS " Nice !
#125
