R50/53 Insanely loud pop/rattle when only 1 window is down
Hi all; I've browsed the forums off and on for years, but haven't had an account until now. I've finally found a problem that I can't find the answer to by looking at other people's questions! So, I'm hoping to pick your brains.
I have an '06 mini, (bought used in '08 for the record,) that is making a rather wonky noise. At first I thought it was a blown speaker, as it was popping and rattling with bass, but it wasn't consistent. It would come and go.
As of late though, it's started to make a ridiculously loud pop/rattle noise constantly when ever only one window is down and occasionally when we're going over a rough patch of road with the window up, even if the radio is turned off. It is slightly mitigated on smooth roads with the window down, but not much. It does not make the noise while at a stop. When I say it's loud, I mean it can be ear-splitting.
I've seen references similar to this, but nothing that incorporates all of these issues. I'm trying to avoid taking it in to the dealership for this as they want $300 just to do a once-over of the vehicle, but it's driving me crazy. Hopefully someone can help!
*edit: It's about half and half on whether it will make the noise with both windows partway down. Both windows all the way down, it won't make the noise at all. Also, the rattle is from the passenger side.
TYIA
TYIA
Last edited by Curio; 11-20-2014 at 05:18 PM. Reason: I forgot important information...because I'm bright like that
There are two little white clips that hold the cables that run across the upper middle of the door cavity, when they break or not clipped in when you put the window down they snap against the window and make a noise. They snap into the door frame and hold the cables.
http://www.ecstuning.com/Mini-2006-Cooper-R53-S-Coupe-L4_1.6L_W11B16A/Interior/Window/
Holding the cables.
Holding the cables.
Edit: It does also happen when only the passenger side window is down, to clarify. It seems to be dependent on 1 window being down, no matter which one. The popping never changes location though.
old thread resurrection,
I have the same problem where a loud pop or crackle or static noise comes from the passenger side speaker under many circumstances:
One window rolled more than half way down while driving more than about 30 kmh (doesn't matter which window). Goes away with both windows down!
When closing the passenger door it makes a loud crack noise that is definitely coming from the speaker (taped a pillow to the speaker and it was muffled). Can't hear it outside the car but frickin loud inside when a passenger gets out and shuts their door (and i've even asked them to close the door gently to no avail)! Edit: does it even when the radio and car are "OFF"
Music more than about 1/3 volume will randomly make crackling noise from the speaker too.
edit: I've pulled the door panel off to investigate and there's no loose pieces or bad wire connections. Speaker looks intact...
Car is a very base model 02 non-S. (intentionally plain jane as it's also my auto-x car)
Yes they rattle even when off. The center coil of the speaker cone is moving with the vibration of the vehicle. You should be able to tell by moving the speaker cone with your hand. If it’s bad it will make a grating popping sound when you move it. The speaker cone serves as an amplifier for the sound.
daviday
09-25-2015 01:31 AM
