R50/53 Leak can't figure it out!
Old 10-28-2014, 07:32 AM
Big John O's Avatar
Big John O
Big John O is offline
Got up this morning noticed a leak under my 2006 mini. after checking leaking seems to be coming from two bolts sticking down under the car. Leak is clear oily substance, checked brake fluid full, motor oil down 1/2 quart which always seemed normal to me, fluid is oily but clear and no smell. Manual trany, clutch seems to work ok. HELP
Old 10-28-2014, 07:43 AM
quikmni's Avatar
quikmni
quikmni is offline
Could use a little more information to help.
Is your 2006 Mini an S or standard Mini?
What are the bolts connected to?
Where are the bolts?
Is it just fluid dripping from above onto these bolts?
How about a picture.
Old 10-28-2014, 01:40 PM
nkfry's Avatar
nkfry
nkfry is offline
Without more information I would say it's powersteering fluid, which is a very common leak on these cars unless you replace the crimp clamps the factory uses with worm style clamps.
More information would be required to diagnose what exactly your leak is, but clear and oily leads me to believe it's powersteering fluid.
Nick
Detroit Tuned
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old 10-31-2014, 08:48 PM
David.R53's Avatar
David.R53
David.R53 is offline
Noticed the OP hasn't responded to questions, so will add without expecting much - The supercharger oil is clear as well, assuming you have a supercharger. Not much to leak out - and pricey to replace - its in the front of the engine of course.
The power steering reservoir is close to the firewall. The power steering fluid is slightly amber, but a thin layer probably looks clear.
If you haven't seen this trick before, leaving a clean sheet of cardboard under the car overnight helps pinpoint drips.
Filmy
15
06-06-2023 06:27 AM
hockeydad51
10-09-2015 01:51 PM
marc0011
09-10-2015 10:04 PM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
09-10-2015 12:34 PM
09-02-2015 09:05 AM
Quick Reply: R50/53 Leak can't figure it out!
