Advice: Changing original plugs, how hard to crank Seized??
my original plugs are on my JCW 2004 MINI S
Went to put new plugs in at 128k and they aren't budging.
How hard do I crank or should I take it to the dealer? They aren't budging with full shoulder strength on the tool. Are they seized? Is there something I could spray down there to loosen them?
Location: Perth West Australia in an industrial unit with my numerous cars.
on
1 Post
The dealer has no magic to get the plugs out. If one snaps it snaps!
I would have to use my 24" breaker bar on this job. Presuming the plug comes out buy/borrow/hire the correct tap, cover it in grease and chase the thread.
Use plug grease/never sieze in the new set.
If one snaps -at leaset you didn't have to pay someone to snap it for you. The repair cost would be the same, as the dealer will not take the blame..
I would recommend kanokroil instead of PB. It's f-ing magic. Make sure the engine is stone cold when cranking on the plug and go easy on it.
When/if the plug breaks free, back it out slowly. If it feels like the threads are starting to bind up again (even slightly), thread it back in a 1/2 turn and back it out again. Repeat this until it's completely free. This has been a fail proof method for me; I've never stripped a spark plug thread in 20 some odd years of working on cars.
KanoKroil Gets My Endorsement!! Sweet Success
Drove 50 miles round trip to get the Kanokroil even though I had the PB in the garage, Not taking any chances! and Success! Blackeyedsuzie Always my Faithful! gave up the old spark plugs in favor of new equipment and a special bath!
You Betcha I talked her all the way through it!
Vendor
Yes try the Kanokroil that stuff is good.
If it still doesn't work better, try to warm the car up for a minute. Not full temp, but just a little heat in the engine may make them come out.
