R50/53 supercharger oil
IMO it is just buying time.. the whole setup is a Sealed system, you go down in fluid when the seals start to fail. So if you keep topping it up, that should accelerate as the seal keeps failing and eventually the gears will start running dry and eat themselves.
other strategy - buy a new SC and then you will have ~100k+ miles of no need to refill the fluid.
My SC lasted 130k miles.. i refreshed the fluid once (while i was in there) and didn't have any leaking.. that was just under 100.. i didn't maintain and then the SC let go. I got a new one and everything is good since. (i did have a defective one which let go at the track - gearbox exploded.. think a tooth failed = lots of smoke & noise)
phil.
phil.
I could have sworn you drain the catch can at oil changes, not top up. My goto sources don't bother with the catch cans though.
The blower oil gets changed if you want it to keep on truckin'. I used the blower oil from Chevy. I'll see if I can find out what it was. I know it was 2 quite small bottles. Also if you change the blower oil it gives you an excuse to replace your water pump.
Yea, I'm kinda confused. The Bentley shop manual shows how to add/change the SC oil. I'm guessing the fill plugs are for something????
I highly recommend changing the fluid and all seals unless you want to buy an sc... I have the original supercharger to my car and its still running good at 128k. I Changed the oil when I got the car at 69k and did it again at 110k and did all the seals and gaskets on the second time around. Still seems quiet and making full boost so despite what people say about "buying time", its a valuable maintenance item. oil is like $12 or so per bottle and requires two bottles each time. Use the AC Delco brand, Outmotoring.com sells it.
Big job but fairly inexpensive compared to buying a new or rebuilt supercharger.
For reference, ECS has all the seals needed and there are tons of DIY's around if you plan on doing the fluid change.
Yea its right here AC delco SC oil :
Part # 12345982
http://www.ecstuning.com/Search/SiteSearch/12345982/
11657540124KT SC ( NON JCW ) They all have the updated Teflon coating.
http://www.ecstuning.com/Search/SiteSearch/11657540124KT/
And the SC Seals kit. 11610020836KT
Supercharger Service Kit
http://www.ecstuning.com/Search/SiteSearch/11610020836KT/
Thats all the main parts for reference.
Part # 12345982
yukinoinu
09-20-2015 09:10 PM
08-25-2015 01:28 PM
